12-05-2006, 04:14 PM | #1 | ||
Hey just curious if anyone knows how evl elf is going with the new owner and what stage it is at ?
12-05-2006, 05:17 PM | #2 | |||
Who is the new owner?
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
12-05-2006, 07:47 PM | #3 | ||
Dunno but i heard theres a T5 goin in it?
12-05-2006, 08:49 PM | #4 | ||
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
13-05-2006, 02:53 PM | #5 | ||
Yea wats happening with my old ride?
how is it? |
14-05-2006, 12:12 AM | #6 | ||
she's currently taken some repairs will be at calder soon..... currently running n/a late model el motor for RWC!!!!
14-05-2006, 08:36 PM | #7 | ||
N/A Oh god!
Thats alsome wat u need for a roady dude? |
14-05-2006, 11:22 PM | #8 | |||
I would have loved to buy that car, but I have nowhere to store it, and my finances would have been spread too thin trying to keep two turbo EB's insured and running! |
16-05-2006, 02:16 PM | #9 | |||
hey mate hows the navy treating ya? I'll write the list down. I was expecting him to say it was too low cause he had to get out a little jack to get the car on his hoist !!!! he would have passed the turbo if I took the intercooler out and had an airbox instead of the pod!!!!! i'd have a fun time getting past vic roads though... I thought i'd just make it n/a soon as I am replacing the bottom end anyways. Aim headlamps washers not working dash switch to be secure.... didnt fix it up when wiring interior lights front lights to be white pedal pads to be rubber horn to be working front bumper missing....... took it off to be repaired lower ball joints oil leaks at engine and trans all discs to be replaced rear springs to low emission control to be effective........ lack of turbo just about everything can be easily fixed or swapped from my eb 5spd so its really not slowing me down, but work is : I bought a late model el motor for it out of a nl fairlane with 70,000k's on it apparently from ozwreck!!!! isnt driveable yet and I need to take the auto back out because we forgot to replace the dud seal :.... if I dont get time before I want the rwc I'll just run silicone around the inspection plate and get rid of it afterwards. |
16-05-2006, 07:04 PM | #10 | ||
Oh wat thats pritty good.
I though it would need heaps more then that.. Yea navy is going alsome, I jst wanna see my old car going good again!! Take ur turbo back and get the shaft play fixed while it's all off.. it's got a year warrentry! EVL-ELF |
31-05-2006, 07:38 AM | #11 | ||
Lost the post!!! :S
Ya recon I should?? I've been told its buggar all movement by a couple of people but while its off I might as well give it a shot !!! how bad do you consider it to be?? my mates got a lot of the turbo gear atm because his copying everything to turbo his XE with an eb motor in it, gives me something to compete against !!!!! I'll take a picture of the 6th cylinder off your old motor for you later I think its rather amusing!!! do you know what type of walbro fuel pump its running? el motors running little rich we are using the fuel reg off the old motor but without the rising reg connected to it!!! will try a different reg in it on friday!!!! |
31-05-2006, 06:27 PM | #12 | ||
Hey dude,
The fuel pump will handle 500 HP. So it's rated pritty high.. Dude get them piks up Staight away. i wanna see em! My head was full worked so if ur building a new engine use my head.. IF it's isn't fukt! Well my mate has a turbo's SR20 and his turbo dont move at all.. I rekon ur's may be on it's last legs ATM so why's it off take it bak to snort.. EVL-ELF! |
31-05-2006, 07:11 PM | #13 | ||
alright cool!!!
ya recon jeoff will remember the car?? might send a few photo's with the turbo to jog his memory!! the people who have looked at it cant beleive it spools up so quick!! I like the port polish job on the head!! it looks alright but their was a fair bit of presure in the cooling sys so might be a chance its cracked!! will get them pictures up soon enough. I need to take them again cause I was too close and all you can see is white!! where u planning on putting injectors and computer into it?? |
31-05-2006, 10:09 PM | #14 | ||
I bought the rims. Put them on a couple of weeks ago and they look awesome! There is still a problem I found with it, for some reason after I put them on my front right guard seems to be below the tyre, but the left one is fine. Here are some pics.
31-05-2006, 10:51 PM | #15 | ||
hahaha TQE plates. Nice! Mate check that your springs are seated properly, it deffinately looks lower on the drivers side. Mybe the tickford badge weighs it down and the 4.0 badge raises it. :P Oh and dump the rear another inch and it will look mint.
31-05-2006, 10:56 PM | #16 | |||
btw nice car Obriza
01-06-2006, 10:05 AM | #17 | |||
The rear could come down another two inches I reckon. It's looking good, they're very nice rims.
01-06-2006, 06:25 PM | #18 | |||
Hey mate it was a matter of money.. I really wanted a wolf 3D or somthing like that.. But i couldn't save due to the fact other stuff needed to be fixed! or updated u no.. Yea the wheels look good on that other falcon Hope the back gets a dump sooner or later! : EVL-ELF |
01-06-2006, 08:30 PM | #19 | ||
Obriza - your car looks hot as man! I love it! Don't stress about your ride height either, unless you get it on a 4 post wheel-alignment hoist and it is still noticably wonky. Your car is parked on grass in what looks like your front yard - the yard would be nowhere near level, hence why your ride height looks a bit off.
The car looks tough get a big polished cooler hanging out the front, and a turbo to match... |
01-06-2006, 08:46 PM | #20 | ||
and give me them XR light's:P
thay'd look better on my car lol nice rim's man dump that *** |
02-06-2006, 07:06 PM | #21 | ||
springs have a drivers side / passenger side ..?
if so ,,Obriza are yours fitted correctly . dave ..
http://img.photobucket.com/albums/v1...toms/done1.jpg |
02-06-2006, 10:44 PM | #22 | ||
GET SOME PIX UP OF ME FUKT MOTOR!! lol :
04-06-2006, 04:15 PM | #23 | ||
should be uploaded?????? I think....
04-06-2006, 04:24 PM | #24 | ||
batteries are dead mate..... cant get em off the camera soon..... 6th cylinder was cracked and was caked in oil!! explains why it painted my shed wall black!!! my mates taken the bottom end to rebuild it!!!!
06-06-2006, 08:13 PM | #25 | ||
