Old 01-07-2006, 08:58 PM   #1
nitroman
nitroman
nitroman's Avatar
Default Electric Supercharging
I've noticed these electric superchargers for sale on the web for 300-400 dollars that claim to produce 2-3 psi boost at full throttle. has anybody used one and do they make any power. has anyone installed a "proper" blower on their Xr8?
nitroman is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 09:10 PM   #2
Casper
Contributing Member
Casper's Avatar
http://www.fordforums.com.au/showthr...c+supercharger
This thread should clear it up for you
Older, wiser, poorer.
Old 01-07-2006, 09:54 PM   #3
LUXO_8
windsor user
bwahaha i'd forgotten about that thread...
cheers for that casper....what a great laugh
Old 01-07-2006, 09:55 PM   #4
Casper
Contributing Member
Casper's Avatar
yeah, I read it again too and had a good old chuckle
Old 01-07-2006, 09:55 PM   #5
nitroman
nitroman
nitroman's Avatar
Hmm... I'ts not so good as it seems is it? Why can't somebody make an electric blower that makes 6-8 psi like a proper belt driven one ? As they say life(and horsepower) wasn't meant to be easy....
Old 01-07-2006, 09:57 PM   #6
Casper
Contributing Member
Casper's Avatar
Wink
because the power required to drive it would need a mini electric generator run by the exhaust or crank to power it.... which basically can be removed by running the blower directly off the exhaust (turbo) or crank (Supercharger)
Old 01-07-2006, 09:59 PM   #7
LUXO_8
windsor user
because it'd draw so much current to be able to supply that kind of psi.... you'd have to upgrade the whole electrical charging system ( decent batteries, mammoth alternator) and it'd end up costing the same as a powerdyne supercharger kit
its far easier to take the drive off the crank like a propper blower does
Old 01-07-2006, 10:08 PM   #8
nitroman
nitroman
nitroman's Avatar
Bugger.. I'll just have to keep playing with my cam timing. I installed a Ford Motorsport e303 cam in my Xr8 last week and it has killed the bottom end power, so I'm waiting for a Rollmaster timing chain/gear setup to show up so I can advance the cam a few degrees to get back some of what I lost without losing too much of the now great top end power. You get nothing for nothing eh.
Old 01-07-2006, 10:11 PM   #9
Mark351
Built Ford Tough
Mark351's Avatar
If you install a flux capacitor with the electric supercharger, ensuring the air-conditioning is hooked up to the intercooler, the benefits are amazing!
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 10:17 PM   #10
nitroman
nitroman
nitroman's Avatar
I'll have to watch back to the futre again to get the details....
Old 02-07-2006, 04:13 AM   #11
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
The good old flux capacitor , fixes everything !
:eclipsee_
XR6-VCT-2000 is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 09:04 AM   #12
Stav
Smile
Stav's Avatar
I remember this...I got played!!! :
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 02-07-2006, 09:40 AM   #13
EvilChief
Boost Addict
what are the specs on the cam? If its designed for top end power/torque, u will never get ur bottom end back to what it was before, not even an adjustable cam gear will fix that.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 11:50 AM   #14
nitroman
nitroman
nitroman's Avatar
The cam has 220' at 50" and 498" lift. Apparently it can be timed into 2 power ranges, 1800-4800 and 2500-5500. I installed it with the standard chain setup(being a tightarse on the day) and it kicks in at 2500 and pulls strong to the limiter,which of course has killed off the bottom end takeoff grunt so I'm hoping advancing the cam 4 degrees or so will bring it into the lower power range.
Old 02-07-2006, 11:55 AM   #15
LUXO_8
windsor user
is it auto or manual? ( im presuming its auto)
sounds like you need a hi stall torque converter
Old 02-07-2006, 12:31 PM   #16
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
You only get what you pay for.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 01:34 PM   #17
EvilChief
Boost Addict
4 degrees is a bit, might start with a little less degrees. the cam doesnt sound too overly wild (or i have seen worse :newangel, so yer with an adjustable timing gear you should be able to bring the torque range a little down. In general its always a good idea to setup an aftermarket cam with adjustable vernier gears. have fun :eclipsee_
N12 Pulsar - sold
Old 02-07-2006, 03:03 PM   #18
GK
Walking with God
GK's Avatar
Engine running, flux capacitor... fluxing! LOL! :hihi:
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 02-07-2006, 04:07 PM   #19
nitroman
nitroman
nitroman's Avatar
I wouldn't mind fitting a high stall converter, trouble is the 100k cruising speed revs are about 1800-2000 rpm so i would have to fit a lower diff ratio (maybe 3;9) as well to make it work. By the way, are the au irs diff crownweel and pinion the same as any old borg warner, ie can I get a diff from the wrecker and use the guts in my diff?
Old 03-07-2006, 07:56 PM   #20
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
dial the cam in properly by going by the specs. usually the easiest is the lifter rise on the overlap on the inlet valve.
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2006, 08:01 PM   #21
S3SR
S3SR's Avatar
isnt that exactly what a hi-clone does?
i thought about this also and found to make the fan stand alone or run from the engine it would draw about the same amount of power it produces..most likely even reducing the power
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2006, 04:24 PM   #22
REDAUXR6II
REDAUXR6II's Avatar
aaaaaaaaaahahhahahhaha what a load of bollocks, you want a super charger then bloody buy one.....not one of these modified hair dryers.
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2006, 05:17 PM   #23
LUXO_8
windsor user
going from the stock 3.45 ratio diff to a 3.9 ratio would increase highway revs not decrease them....
a stall wont alter the highway cruising speeds ( well it shouldnt ) it will just allow the vehicles "take up" point to change from the stock 1700 odd rpm to the higher rpm..... your car will bw in its powerband much faster, increasing acceleration...
i'd say your cam picks up at 2500 or there abouts and you're noticing the sluggish low rpm's due to too small a stall speed... a 2500 - 2800 stally would just about completley change the car
Old 04-07-2006, 07:46 PM   #24
nitroman
nitroman
nitroman's Avatar
I know what you mean, It's like slipping the clutch in a manual to a higher rev. I'm just worried about the converter "slipping" while Im at cruising speed when It's supposed to be engaged which might stuff the converter if used as such for a prolonged period.
I've heard that there are converters and there are converters that actually work well. I believe a good converter will lock at a light throttle and slip when you really hit the gas. Who sells the good ones?
And yeah I realise a higher numerical diff (eg 3;9 vs 3;45 ) will increase highway revs. A higher number is called a lower diff ratio for some reason.
I'm gunna loosen my rockers a shim and advance my cam timing this weekend and see how that goes, then I'll have to consider a converter if i don't get the pickup I want.
Old 04-07-2006, 08:06 PM   #25
Lukeyson
Right out sideways
Lukeyson's Avatar
god that was a funny thread
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2006, 10:51 PM   #26
XR6-VCT-2000
Fantastic Plastic
lol , but but but E=Mc squared , so it must work ...lmao ...
I haven't even bother reading the previous thread again , but im gathering it's the thread from a few months back where the dude tryed to cover his butt for ages, insisting that the electric supercharger was worth while ! , but was eventually proved wrong , then he tried to say he was really stooging everyone, seeing how many people he could suck in .. imo eventually i think he was the stooge ! ...lmao ,
:eclipsee_
Old 05-07-2006, 04:00 PM   #27
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Sorry about this, but I was lurking through eBay and found they've taken it to the next step, by adding a pod filter and a "blow-off valve"...
http://cgi.ebay.com.au/electric-supe...QQcmdZViewItem
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2006, 07:42 PM   #28
NeishaXR8_347
SS Grunt
lol i just read that gen 2 one and a guy has a 1.4l civic and he said with this activated he is basically all over the road, pretty hard to believe hehe.
Old 05-07-2006, 08:43 PM   #29
Pinkbits
Pinkbits's Avatar
I've seen the DELOREAN at the Blue power work shop!
Was it there when you were there Mark?
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
