23-07-2006, 08:35 PM | #1 | ||
SLICK EL
hi just wonderin if 8 injectors on a 6 would fit and if so would it be better///
23-07-2006, 08:41 PM | #2 | ||
Formally Kia Chaser
Hi and welcome to the forums.
The I6 injectors should be fine, even with a fair amount of mods. If you inject anymore fuel into the eninge, it will run rich, and you will loose performance. If you want some low cost starting mods, check the Performace Mods sticky at the top of this forum page...
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
23-07-2006, 08:46 PM | #3 | ||
SLICK EL
wat about a lightened fly wheel
23-07-2006, 08:46 PM | #4 | ||
SLICK EL
or twin throttle bodies do .. they make them for au's
23-07-2006, 08:47 PM | #5 | ||
SLICK EL
or twin throttle body manifolds do .. they make them for au's
23-07-2006, 09:11 PM | #6 | ||
Miami Pilot
All of the above are next to useless on an NA I6. Go turbo or supercharger, and then these may work effectively. More petrol does not mean more power. But more petrol with lots of compressed air means fun!
23-07-2006, 09:20 PM | #7 | ||
SLICK EL
ohok ...there was a commowhore on a web site wit twin throttle bodies and 8 injectors...just wonderin if it actually produced more power..but obviously not..
23-07-2006, 09:23 PM | #8 | |||
Miami Pilot
23-07-2006, 09:25 PM | #9 | |||
Was V6corp
As much as i love how u put that... he was only asking, and thats how most of us learn.
Car: 99 AU I Forte Sedan Colour: Blue Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash Bling Mods: Tinted Windows; JVC CD/DVD HU Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags |
23-07-2006, 10:58 PM | #10 | |||
XB in parts...
Your injectors will cope just fine until you start to seriously modify your engine.
Daily Driver 2019 Ford Escape...looking for XR6T's. |
24-07-2006, 09:30 AM | #11 | ||
Formally Kia Chaser
As you get more into doing up your Ford properly, you will realise that there are quite a few commodores (I should actually say cars) out there, many with useless mods... V8 injectors, larger exhaust tip, larger tb's. Like you have done, you need to first ask what benifit they will give to performance, or with what combination of parts, which is what you have done.
eg. A cam on it self may give you car a 10-30kw gain, but with a flash tune, you may find it can give you upwards of 50kw gains. Same gos with allowing more fuel and/or air into the engine. The mods that do this may not give massive gains, but get an edit, and you will get a small/decednt gain. But edits are only really worth it, after getting: Intake, filter, exhaust, extractors, and more specically, cam, then your edit. These mods combined can give you in excess of 50kw on the AU.... Good luck....
24-07-2006, 10:56 AM | #12 | ||
Check the colour of the injector you have and look up what poundage and flow it is. It might interest you to know that some model V8 injectors are smaller than 6cyl ones. When you divide engine displacement by number of injectors 6's actually have to provide for a bigger displacement per cylinder. My pursuit 250 actually uses the same injectors as a previous model 6 cyl with increased fuel pressure. This was done by tickford. Mine are the blue as used in the sixes. Having said all that you usually have to do a fair amount of mods before you max out an injector. Talk to an expert they have a formula to apply to see if you need to go a bigger injector
24-07-2006, 04:32 PM | #13 | |||
SLICK EL
24-07-2006, 07:12 PM | #14 | |||
RDP #181
Start off slowly dont just jump in with a cam. Extending on what was said above, if you just whack in a bigger cam without making sure that you can firstly, supply the air you need via the intake and expel via exhaust you will loose power than you had to start with.
Start with and exhaust system and if your car doesnt have an lsd do something about that. PS WHAT WHAT WHAT WHAT WHAT WHAT....
24-07-2006, 08:46 PM | #15 | |||
Formally Kia Chaser
A cam can start from $500 just for the cam, but then you will need installation... this price can go up, depending on cam performance, and what materials it is made of... best value for money depends what you want... do you just want a cam for the sake of it, or do you want the most performance, but best economy, etc... a high lift cam with edit would be best value for money for max performance gain, but your looking at about $1500 for a good dyno flash tune, and maybe $1500 again for the high lift cam (labour included). A cam is not worth doing if you do not have an exhaust. If you keep the stock exhaust and put in a higher lifting cam, exhaust gases will flow out of the cylinder easier, but there will be more pressure put on your exhaust manifold, rather then the pressure being put on the exhaust outlets... so basically, it will provide next to no increase... you will probably get some, but for $400, get a 2.5" exhaust... for $1000, get a 2.5" exhaust, hi flow cat, and pacemaker extractors... labour included.... this is the best value for money (bang for buck) bolt on mod that you can do... while you at it, drop in a K&n filter panel.... This is pretty much the first half of the Performance Mods article.....
25-07-2006, 05:34 PM | #16 | ||
SLICK EL
the mods i have already done are ....tickford snorkel,extractors ,exhaust,quickshift,
25-07-2006, 11:14 PM | #17 | ||
Bear with a sore head
What exactly is a "quickshift"? If you have a manual I'm guessing you mean a short throw shifter, and if it's an auto I'm guessing you mean you have a shift kit?
26-07-2006, 06:21 PM | #18 | ||
Boost Addict
correct me if i am wrong, but AFAIK the V8 injectors are similar size to the 6 ones .. just an extra 2 :p
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
26-07-2006, 06:59 PM | #19 | ||
well if you work out the cylinder size, eg 5/8=0.625ml, 4/6=0.667ml, so the i6 injectors must be slightly bigger being that the actual size of the cylinder is...correct me if im wrong somewhere
26-07-2006, 08:05 PM | #20 | |||
Miami Pilot
26-07-2006, 08:45 PM | #21 | ||
Actually they're not the same. The Magna injectors (also used by HSV) are designed to deliver 24lb at a much higher fuel pressure.
26-07-2006, 08:55 PM | #22 | ||
Boost Addict
i was refering to the cc sizing .. fuel pressure brings a compleely different ball into that game
26-07-2006, 09:51 PM | #23 | |||
SLICK EL
