02-08-2006, 09:14 PM | #1 | ||
Smile
Guys I know that the AU transmission has no dipstick but I dont believe the filter had to be changed all the time. Id like to get a plug welded into the pan so I can just drain it and refill it .I cant be bothered to drop the pan each time as it is a pain in the butt.
Has anyone done this?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
02-08-2006, 09:55 PM | #2 | ||
I think it's B&M that do a trans plug kit, but you will have to remove the pan to get it fitted
Pit Lane Performance 20 Rosella St Frankston 03 9783 8122 Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
02-08-2006, 10:08 PM | #3 | ||
Smile
Thats fine.I was thinking I may be able to weld a nut inside and have a bolt with washer outside.Undo the bolt ,refill the plug and voila..dont have to muck around in future with removing the pan every time.
02-08-2006, 10:35 PM | #4 | ||
AUII Fairmont Ghia
im not thinking too well 2 nite but couldnt you do it at the oil cooler line
03-08-2006, 12:12 AM | #5 | |||
Smile
03-08-2006, 04:17 PM | #6 | ||
AUII Fairmont Ghia
you only get about 1/2 by dropping pan rest is in the convertor
03-08-2006, 06:34 PM | #7 | ||
Then how do you get rid of it properly then? Is it a pain to take the convertor out?
03-08-2006, 06:59 PM | #8 | ||
uh yeah...you have to take the transmission off to get the convertor out
03-08-2006, 08:40 PM | #9 | ||
AUII Fairmont Ghia
get a transmission flush any good trans place can do it
03-08-2006, 08:51 PM | #10 | ||
Use a normal falcon sump plug and fibre washer which is 1/2" UNF thread ,drill hole and weld a 1/2" UNF nut inside the pan.Done plenty this way
03-08-2006, 09:29 PM | #11 | ||
Back on the road
A drain plug in the auto pan would certainly be handy...
Dropping the pan is a PITA
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
04-08-2006, 01:33 AM | #12 | ||
Couldn't you use a pump to drain it from the filler hole? Either hand or drill operated would work, maybe.....?
04-08-2006, 07:09 AM | #13 | ||
Back on the road
I've only ever been able to get a litre or two out using a handpump. The insides of the transmission stop the tube/hose from getting anywhere near the bottomof the pan.
