Old 30-08-2006, 02:18 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default 3.23 lsd diff
hey i got quated $350 for a 3.23 lsd diff from the wreakers change over so they take my old diff witch saves me dumping it. the diff is out of a EA and mine is aa EB s1 this will bolt strait up wont it. where u pull it said they charge $160 for the same diff but u have to know what car to pull it off as they have no idea, how would i tell and is it a good price, how would i change the spedo reading to suit diff.
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 02:24 PM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
yes it will bolt straight up.
You will need to change the speedo gear in the transmission to suit the 3.23 ratio.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 02:26 PM   #3
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
how hard is it to change its a compleat diff disk to disk, is it a good price and if i was to go to upull it how would i go about telling what diff they had in them,
where does the speedo gear go
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 30-08-2006, 02:27 PM   #4
Perana
Perana's Avatar
I seem to remember something is different in the lower arms.. not sure though..
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 05:25 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
good price or not
in the serial number can i tell if its a lsd without looking under the car
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 30-08-2006, 06:08 PM   #6
EBFalcs
it should have a tag that says "spin resistant diff use approved lubricant only" or spin one wheel and if they bothe turn in the same direction it's LSD, the speedo gear is simple to change if it is the same as the 3 speed autos and the 5 speed manuals, it is on the drivers side of the gearbox towards the rear and it has one bolt holding it in and a plug about 6 inches from the speedo gear.
changing it disk to disk would be easiest undo swing arms handbrake cable and brake line, remove and put new one in and remember to bleed the brakes.
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 06:26 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
how do i tell the ratio
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 30-08-2006, 06:29 PM   #8
EBFalcs
it should be on the tag or stamped on the housing somewhere, if you cant find either, try figuring it out by turning the tail shaft and counting the wheels turn
Old 30-08-2006, 06:37 PM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
any one got a pic so i know where to look
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 30-08-2006, 09:23 PM   #10
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
any one got one they wana sell and help fit
VE SS Ute manual 09
125 Thumpster 2010
Swag
