Old 05-09-2006, 08:55 PM   #1
lukey
www.lukehimself.net
lukey's Avatar
Default Power Converter
Hey guys I want to run my Playstation in my car and was wondering what kind of wattage converter I need. Would this one do?
http://www.jaycar.com.au/productView...Max=&SUBCATID=
Or would I be better off with the 300W type?
I want one that goes directly into the cigerette lighter to make it easy to plug/unplug. I've never used a converter before so I'm not too sure what to use.
Thanks,
Luke.
Subaru Liberty MY04 4GEN Luxury
www.lukehimself.net
lukey is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 11:25 PM   #2
ktmconvert
Not here
ktmconvert's Avatar
I always hard wire mine through separate fuse box just to make sure. Always go the big one because you may want to add things at a later date.
Also look at getting a deep cycle battery.
ktmconvert is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2006, 07:58 AM   #3
Simmo
White Lightning
Simmo's Avatar
have a look on the bottom of your playstation. there should be a sticker somewhere telling you how many amps the unit draws. base your inverter selection off this. i borrowed a 280w unit from a mate to test an xbox in my car. it ran the xbox beautifully and stayed on while i started the car so i could run little 5 mins battery charge bursts.
Simmo is offline   Reply With Quote Multi-Quote with this Post
