View Poll Results: What do you think is better on startup | |||
Let it idle till it warms up |
115 | 45.10% |
Start moving and drive normally |
140 | 54.90% |
Voters: 255. You may not vote on this poll |
#31 | ||
Last warning
i start it and thrash the shit out of it...
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#32 | ||
And wonder why you bend valves :P
#33 | |||
Boss 350
Closed loop operation happens at idle and cruising only , as the ECU is receiving the oxygen sensor/s feedback which in turn keeps the A/F ratio at around 14 to 15 : 1 which is around optimum for the cats to clean the exhaust gases. Open loop is used for anything else , which is where the mapping comes into play. As for warming up . Start for 30 secs with a few light revs , then take off. |
#34 | |||
As for open loop, it is usually engaged at power enrichment mode which most of the time is WOT but not necessarily. As for 14.7... that's stoich and that occurs when the mixture is nearly 15 parts of air to one part fuel ... which is normally at cruise (i.e. when the economy is best). You sound like you think you know what you are talking about. I will counter your argument with solid evidence if you still disagree. ;) BTW, the cats don't like constant periods at idle especially at cold start as the mixture is very rich and not good for the cats... that's why manufacturers these days move the cats closer to the engine - for faster heating of the O2s and quicker response time in closed loop.
Rep Power: 0 Last edited by SSbaby; 25-02-2005 at 01:43 AM. |
#35 | |||
ooga-lagga-ligga-lagga
and 14:7.1 is the optimum ratio for the mixture to get burnt completly |
#36 | ||
Haha, i just jump in and drive. I'm usually always late for something, so theirs no time for warming up my car, lol.
Me fail English? That's unpossible.
#37 | ||
Windsor Man!
Car engines are not stationary engines, they are designed to carry a load. The best way to warm an engine up is to start it, then drive straight away, but gently. You need to put a load on the engine from the moment it starts. However, you also need to get oil all over the inside. So, just start it up, then take off and drive around gently until it is up to running temp, then, don't you dare let it drop below redline :P
#38 | |||
![]() Join Date: Dec 2004
I start driving pretty much straight away and take it easy for the first 15 mins. My old EA used to cop a flogging, I'd jump in and with no mechanical sympathy start thrashing it before the temp needle had even moved. Now my bro's car it's done about 400,000 and still going strong. Built Ford Tough eh?
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#39 | ||
meow
Just thought i'd add my 2c... 14.7 is the stoichmetric ratio required for complete combustion, ie.. pure oxygen + fuel (some big carbon chain), this is not the case for cars as AIR does not contain 100% pure oxygen, this is why cats are required to filter out the N and C compounds which are a result of incomplete combustion.
#40 | |||
On the GM PCMs you used to have what's called a lean cruise feature until the EPA stamped it out - the AFRs were as high as 17:1- this feature was omitted on US vehicles due to their tougher emission laws. BTW, for maximum torque, the AFRs should be around 11.2:1 while for max power, around 12.8:1 but it does vary slightly between engines.
Rep Power: 0 |
#41 | |||
Fairmont Ghia
Tim |
#42 | |||
Viper FG XR6 Turbo
#43 | ||
i just start it let it idle for a few seconds while i put the sunnies on and set the phone up then drive as normal,,under normal driving conditions you won't hurt the motor or transmission or the diff as they are built for it,,now if you were to redline it on cold start then you derserve what you get,,,a slap up the side of ya ed,
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
#44 | ||
LPG > You
I start the car, let it warm up, then drive off. Keep it a bit light for a while until the gearbox, diff etc warms up.
LPG Lovers Association President & Member #1. ![]() ![]() |
#45 | ||
DJR TM#54
I start it let it idle for about 30sec than drive off slowly till it warn up.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
#46 | ||
My manual warns me not to let it warm up for more than 20-30 seconds.
#47 | ||
I usually let the car idle for 30 seconds before I start to drive. This is not enough to warm up the car but is enough time to allow 'everything to settle'. Once on the road I don't start giving the car stick until it reaches normal operating temperature.
FF |
#48 | ||
TUFF FORDS
it depends on the car the xr8 just start and go.. but the cortina with its forged pistons and agressive cam you'd be mad not to let the engine warm up before driving/racing
#49 | ||
Audi S3
i just drive.
#50 | ||
The one and only
I thought this thread died in Feb
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#51 | ||
Start it up and drive, that's the best way to get all parts of the engine warmed up as well as the drive train.
Long idling only warms some parts of the motor and nothing else, giving a false impression that the vehicle is ready for anything. The Territory section had a similar poll awhile back; Do you warm up your Tezz? One important thing to note is engine oil viscosity, thinner oil is better for cold weather start up.
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk ![]() |
#52 | ||
It's Clobberin' Time!
I start it up, buckle up, mirrors etc and then I'm away. Not to much in the way of warm up really.
Owner/Driver of: 2009 Velvet FG G6E Former Fords: 2003 Blood Orange BA XR8 1993 Winter White XG S Ute |
#53 | ||
feza
i have an ea spac sedan 4sp auto,i wait for oil pressure to go up and lifters to quieten down,there a bit noisy on start up then cruise off normally,no real warm up period at all.i wait a bit before i start givin it a hard time,dont really cain it though cos its a gutless auto.need to put my t5 in it
#54 | ||
Once PHASED.
I just wait until my oil pressure reaches normal specs, then drive the car normally..
2006 BF XR8 Bionic. |
#55 | ||
Can man
I start it up and go lok the house up, which takes about 3 mins or so. Then put it in gear and off we go.
I dont give it a hard time though, just low revs till its warmed up, then i drive it normally after that.
![]() ![]() :2007 PJ Ranger duel cab 4X4:
#56 | ||||
FGX XR6 Lightning Strike Sedan BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw. Quote:
#57 | ||
todays car guide said the best way to warm up a car is to start it and then drive it straight away.
#58 | ||
With the VL, I just start it up and let it idle over for a couple of minutes.
I've had to do it, because sometimes on start up it's misfires a bit and chugs. It's brilliant, after it's warmed up though.. |
#59 | ||
Churches Eat Souls
I usually give it about a minute. Then I don't exceed 2,000 rpm until full operating temperature.
#60 | ||
99FalconS
Get moving straight away but dont stress the engine let warm up.
Most thinf=gs i have read say that you dont need to let it idle and that it just a good way to waste fuel. |
