hey guys would i be able to put a xr6 ef manaul ecu into my eb when i convert it into a manual and if so will there be any benefits i know they make it rev another 400rpm.
cheers scott |
it wont work, the EF's run 100 pin ECU and use coil packs, the EB has a 60 pin ECU and runs a dizzy. you can use an EL XR6 manual one providing that your car has smartlock.
just double checked the ecu im looking at is out of an el not an ef
should be OK then. does your EB have smartlock?
yeh mate i got smartlock wat benefits do you think it will have and how much would you pay for one?
it changes the fuel mapping allowing you to run a lumpier cam with minimal loss of idle quality. will also let you run thermo's with out the need for a temp switch and also you will be able to run a BBM easier too.. i paid $200 for my manual ED XR6 one.
Im looking at $300 for the el one is the ed one simular to the el one?
the ED one has less features than the EL one ie BBM stuff/thermo wiring...and id assume the mappings are slightly different again. both dont have the speed limiter.
do you think $300 would be good buying then?
no idea, im not to sure what there worth, im sure someone would know.
hibernating
$300 sounds ok... el xr6 manual ecus are very hard to find and a fair few people are looking for them
#12 | ||
sox stuck one in hisxh ute which is fairly worked up he told me that although it didnt go any harder idle was improved and it was a bit more responsive to throttle.
#13 | |||
Formally ED I6
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
#14 | ||
ok thanx guys now do i have to do any mods when i decide to hook the ecu up or do i hook it straight up.
thanx scott |
#15 | ||
