Old 01-07-2007, 03:07 PM   #1
tobiasm
Default Serpentine belt
g'day all,
Im currently replacing the alternator on my AU III XR6 VCT & have encountered a problem putting the serpentine belt back on. Im not sure how to loosen it & am having great difficulty trying to finish the job.
Any help would be much appreciated.
tobiasm is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 03:19 PM   #2
trick_xd
I build your wish list...
trick_xd's Avatar
just use your hand and pull it up .
I find it easier to slide it off the water pump.
and when putting it back on I put it on the power steering pulley last.
Stand at the drivers side grab the belt and lift up
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 04:47 PM   #3
AUXRVIII
The tensioner has a square 3/8 hole for fitting a ratchet or breaker bar to release tension on the belt for removal and refitting. It's also easier to remove the cooling fans.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2007, 08:40 PM   #4
EvilChief
Boost Addict
spot on ... cooling fans are not neccesary to remove, i have found a pipe extension on the breaker bar makes the job easier
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 13-07-2007, 02:06 PM   #5
irext
I'd rather be Fishing.
I just pulled on the belt until the 3/8 hole in the tensioner lined up and slid a drill bit into it. Replace the belt (a bit fiddly) and then reverse the procedure. No tools necessary!
irext is offline   Reply With Quote Multi-Quote with this Post
