04-07-2007, 09:17 PM | #1 | ||
I've been drifting with some mates and I reckon it's fun as.
We done it in a Toyota Camry and he throws on the handbrake and turs the wheel. I'd like to do it in my ED (in the right place of course) but he said it's different for Rear wheel drive vehicles. Also my handbrake is an umbrella type which I'm unsure if it makes a difference. So what's the best way to drift in my car? It's a stock ED falcon classic. |
04-07-2007, 09:19 PM | #2 | ||
Rockin '67
I'm guessing your talking about on a race track and not on a public road? round a corner throw it into first and give it some revs. but not on a public road. make sure you only do this on a race track
04-07-2007, 09:20 PM | #3 | ||
turn and hammer the throttle
04-07-2007, 09:20 PM | #4 | ||
low wagooon
boot it round the corner if its auto and hope it kicks back lol or if its manual dump the clutch. A stock ED wont be the best for drifting
Webby
S2 AU XR6 UTE |
04-07-2007, 09:22 PM | #5 | ||
ORSM Ford Cruisers
drift set-ups in e-series has been gone over a fair bit. its basically, suspension, power and money.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
04-07-2007, 09:22 PM | #6 | |||
04-07-2007, 09:25 PM | #7 | ||
well mate as the previous posts mention go around the corner then hammer out of it in 1st and make sure you dont over correct!! the best way of doing this is by keeping the wheels angled the way you want the car to go! obviously if your rear end is drifting to the left you pull the wheel left hand down but make sure you dont pull it past the point you are heading!! otherwise you will over correct and spin out- over correction is the most common mistake made in drifting!! Good luck son!!
04-07-2007, 09:29 PM | #8 | ||
04-07-2007, 09:33 PM | #9 | ||
Aspiring mr efxr
stiffen up ur suspension a bit first, particularly the rear as u still want the front to grab the road (nolathane bushes maybe shortened or low flowing shocks). whack a camber kit on the front and give it no more than negative 2 degrees to start off with. then practice practice practice. its gunna be harder in an auto as somethimes it doesnt kick back into 1st quick enough if at all then u get understeer n ur in the grass.
as u get more of a feel for it fiddle with ur set-up (suspension, final drive gearing) but only change one thing at a time as u may go 1 step forward and 3 back
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
04-07-2007, 09:33 PM | #10 | ||
hahahaha Camry drifting....ok.
And apparently no one knows the difference between over steer and drifting. |
04-07-2007, 09:35 PM | #11 | ||
Thanks guys.
What speed should I be going when I put it in first? It doesn't sound healthy for the transmission. We drift on our mates paddock. |
04-07-2007, 09:38 PM | #12 | |||
www.TUFFCARPARTS.com
And illavitar, I somehow don't think your column shift auto, umbrella handbrake, bog stock 6 ED is going to be the best, or easiest thing to drift....
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
04-07-2007, 09:38 PM | #13 | ||
Back on the road
watch Best Motoring "Drift Bible" a few times.....getting the technique right will be a pretty good start.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
04-07-2007, 09:39 PM | #14 | ||
Aspiring mr efxr
depends on the corner. if ur just stuffin around in an open paddock around cones or something id put it in at about 25km and hook it hard around the corner and mash the loud pedal at the same time and she should kick out. its not that unhealthy
04-07-2007, 09:41 PM | #15 | |||
Aspiring mr efxr
04-07-2007, 09:42 PM | #16 | |||
Drifting is being sideways before, during and after the corner. NOT kicking the end out by mashing the pedal half way through the corner to bring on a bit of over steer. |
04-07-2007, 09:47 PM | #17 | |||
04-07-2007, 10:02 PM | #18 | ||
Aspiring mr efxr
on ur paddock in the wet on grass u should be able to drift
lock it into first (b4 u go anywhere) approach ur marker at 30km or so, rip the handbrake (keep the button pulled in) let it kick out sideways, about 1/3 of the way around the corner release the hand brake and get on the accelerator(3/4) as ur hand moves down then grab the wheel and feather the throttle
04-07-2007, 10:02 PM | #19 | ||
we need a learn how to drift track day, a skid pan type set-up, looks like heaps of fun but could be costly if you stuff it up!
The Old: 1993 ED Fairmont 1994 ED Futura Classic Manual, 2004 BA MkII XR6 Turbo 2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing) 2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit) The New: 2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade) Other Road Toys Silver Surfer 2014 S-Works Roubaix SL4 road bike with Roval Rapide CLX 40 wheelset The Adventurer! 2023 TREK Domane SL 7 AXS Gen 4 |
04-07-2007, 10:08 PM | #20 | |||
Depends if you just wanna go sideways, or if you want to actually drift. If you just want to go sideways, you only need two things: -Power -LSD or minispool Manual would also help.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
04-07-2007, 10:10 PM | #21 | |||
Aspiring mr efxr
we should organise another one but call it Drifting Practice Day
04-07-2007, 10:14 PM | #22 | |||
[EBGLT]
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
04-07-2007, 10:21 PM | #23 | |||
Is there a skid pan in melb other than at the police training grounds? i'll put my hand up for the next skid pan day :
04-07-2007, 10:21 PM | #24 | ||||
04-07-2007, 10:33 PM | #25 | |||
Hamish ED, Lowered Lovell Springs, Monroe GT gas shocks, SAAS Racing Buckets, SS Lab Sound System, Carbon Fibre Wheel, Full Sports Exhaust System. |
04-07-2007, 10:35 PM | #26 | ||
well trying to redeem myself after 10 seconds of searching i found this:
wikipedia article there is even a ford ute in there (not drifting, but picking up smashed bumpers lol) |
04-07-2007, 10:43 PM | #27 | ||
lol @ going to wikipedia to learn Jedi Drift Control techniques
04-07-2007, 11:59 PM | #28 | ||
I reckon!
Anyway, if you are drifting in a paddock you should be able to get the gist of it just from mucking about. I learnt quite a bit in my parents 1988 tarago, unbeknownst to them The best way to get these cars to drift is to use a "scandanavian flick", because the handbrake is woefull at best, and very hard to pull up and release. As others have said, put the car in first (auto) or second (manual) and approach the corner you wish to take, at a steady mid-throttle and at an appropriate speed. Start off slow so you get the feel for it. As you come up to the corner, lift off while at the same time flicking the wheel AWAY from the corner briefly, then bringing it back hard in the direction of the corner, while at the same time nailing the gas. On grass you will most likely have to liff of pretty quickly after that and countersteer big time while feathering the throttle. As you get through to the end of the corner, start gradually lifting off to bring the back of the car in as you wind off lock. Practice makes perfect |
05-07-2007, 01:03 AM | #29 | ||
Aspiring mr efxr
seems we're drifting here should we get technical?
scandinavian flick = rallying faint = drifting although its the exact same thing lol ;) mate we all apparently are experts but if ur gunna take anyone's advice take Rollin's. just get out there, muck around, and learn by doing it
05-07-2007, 01:22 AM | #30 | ||
yeh it really isnt hard to get the car sideways on dirt. it is getting it sideways and doing a real drift that is harder.
if its on a paddock and just want some sideways action for the fun of it. i used to do it constantly in a datsun 180b. just floor it and turn. good chance the back will slide out. but probably the whole car to so have plenty of space. as has been said. play around and you will soon work out how to control it. |
