06-07-2007, 08:36 PM | #1 | ||
Well i just picked up a K&N RE-0810 9in pod filter from americanauto's for $74.50. It's the same pod the G&D performance use in there $600 intake kits. Also has a 3in neck. Autobarn and repco wanted around $180 for the same item. Americanauto's seem very cheap with K&N stuff.
Going to fit it saturday inside the original airbox although I am planning to cut the front tray of the box to fit this big berther in snugly. Here is a pic of it next to a SAAS pod filter which is the standard pod filter size. |
06-07-2007, 08:53 PM | #2 | ||
why...
06-07-2007, 08:53 PM | #3 | ||
Kudos on the big pod mate but i think you have over done it.
06-07-2007, 08:56 PM | #4 | ||
it's not the size it's how you use it ;)
06-07-2007, 08:57 PM | #5 | ||||
AFF's 1st DM.......
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
06-07-2007, 09:03 PM | #6 | ||
Seriously mate, I bought this because i couldn't justify outlaying $600 for a G&D intake system when i should get similar results for about $90 when you include the silicon adaptor,45 degree bend and 1 hour of my time..
cheers..... Last edited by LTDHO; 07-07-2007 at 01:27 PM. Reason: deleted post removed. |
06-07-2007, 09:07 PM | #7 | ||
Use the small one, you'll notice a difference, your's being the bigger one, you'll notice the same difference as the small one.
That big one, waste of space in my opinion Last edited by LTDHO; 07-07-2007 at 01:23 PM. Reason: Post cleaned |
06-07-2007, 09:19 PM | #8 | |||
Highway Taxi
mmm.. please post your results
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
06-07-2007, 09:40 PM | #9 | |||
So i am pretty sure i will get some good results with this K&N pod, flows at a higher CFM and has more surface area than the standard panel filter. G&D performance wouldn't use them if they sucked. They R&D everything on the dyno, check out there website!!! and have a read..... Last edited by LTDHO; 07-07-2007 at 01:29 PM. |
06-07-2007, 10:03 PM | #10 | ||
damn thats a huge pod filter, best of luck , i reckon ur pedal will feel nice n stiff too!
Let me know the results! cheers - Grechie
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
07-07-2007, 08:30 AM | #11 | ||
thats a big bi atch !
Heritage Green EL Ghia Black AUII XR8 Ute |
07-07-2007, 12:51 PM | #12 | ||
EBII XR6
Is it to go on a ef/el or ea-ed?
DEVLXR
07-07-2007, 01:02 PM | #13 | ||
Tuned @ Pitlane Frankston
2rwkw's here we come!
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
07-07-2007, 01:24 PM | #14 | ||
Aspiring mr efxr
isnt it a greater surface area for more air to flow through also? i've baan considering one of these style pods for an in box arrangement
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
07-07-2007, 01:26 PM | #15 | |||
07-07-2007, 01:27 PM | #16 | |||
regardless youll notice very little difference |
07-07-2007, 01:28 PM | #17 | ||
The one and only
Thread cleaned.
Please keep on topic and replies relevant. Thanks,
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
07-07-2007, 01:32 PM | #18 | ||
are you going to plumb the front where your going to sut the box?
07-07-2007, 01:40 PM | #19 | ||
Aspiring mr efxr
well i plan to cut a hole in the bottom of the box to get air coming through the front bar (i have no lights in it) and getting one of those $30 intake pipes from autobarn (which i think are 3") and an EL rubber elbow to the t/b. it a mild intake mod and i dont expect the world from it.... i just thought with the extra air that the bigger pod would be more appropriate
07-07-2007, 01:43 PM | #20 | |||
Back to Le Frenchy
Better off gettin a 3" mandrel bent pipe made up with a 3" silicone joiner to the TB. With a bit of work the pipe fits nicely into the back of the airbox lid and with the big pod hanging off the end of that and a decent amount of cool air getting in you should see some decent gains.
07-07-2007, 01:51 PM | #21 | ||
be sick & stick your phallic pod in one of these motherfrankenfurters:
07-07-2007, 02:25 PM | #22 | ||
Team Urinal Cake Racing
You will notice sfa imho
07-07-2007, 02:28 PM | #23 | |||
07-07-2007, 04:12 PM | #24 | |||
Aspiring mr efxr
07-07-2007, 05:16 PM | #25 | ||||
Back to Le Frenchy
07-07-2007, 06:37 PM | #26 | ||
Aspiring mr efxr
yeah.... but cheap.
so how come is it that these AmericanAutos lot charge such a low price for a K&N pod?
07-07-2007, 07:20 PM | #27 | ||
Had a few dramas installing this big berther in the box so i have just secured it with a pod bracket and lowered it in the airbox tray. Have ordered some heat shield material today from autobarn to fully enclose it next week.
http://www.aclperformance.com.au/prod_heatshield.htm After taking it for a long drive all i can say it is a TORQUE MONSTER. Power is up through the rev range. Bascially 3/4 throttle gets the same response as full throttle with the stock airbox. But the torque through low and mid revs is fu%ken awesome. The car just pulls, it really benefits the pacemakers and exhaust. Also fuel economy at instant on trip meter is averaging 1-2litres less than the stock airbox. I am one happy camper Post some more pics next week of the fully enclosed heat shield.. cheers Last edited by fairmont1998; 08-07-2007 at 10:46 AM. |
07-07-2007, 07:28 PM | #28 | ||
Aspiring mr efxr
lol that looks great! post up some pics once u have the heatshield on it
08-07-2007, 04:19 AM | #29 | |||
It's the first time someone has actually tried a pod filter that has more surface area than the stock panel filter and also being a K&N. Don't be so quick to do the lol..lol.. lol..thing I will post pics once completely finished, but i will have too say the gains i have already got, have far out weighed the performance gains i got from fitting a 2.5in sports exhaust. |
08-07-2007, 10:48 AM | #30 | ||
The one advantage I can see with such a massive surface area is it'd take much longer to get dirty enough to affect the airflow.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
