10-07-2007, 08:44 AM | #1 | ||
Hi,
I have a Manual LS Focus CL and the Engine Warning Light has come on. I have done about 22,000kms and the car still seems to be running smoothly. I have booked the car in for somebody to have a look at it, but was just wondering whether anybody on here has had anything similar happen with their car. I am using 95 Unleaded primarily with a bit of 98, have had the car starting issue a few times, but nothing recently. Any recommendations/advice would be appreciated. Cheers
BF Fairmont Ghia 2006 - Lightning Strike |
10-07-2007, 09:05 AM | #2 | ||
AFF Post NAZI
might just be a loose sensor cable or some what. but its good that you have booked it in.... get it checked out...
"Its not always about power, The car has to handle Beautifully" |
10-07-2007, 03:26 PM | #3 | ||
Sounds like the throttle position sensor. A few other members have needed their's changed. Does it happen at startup onward or only after driving for a little while.
http://fordforums.com.au/showthread.php?t=65958 |
11-07-2007, 07:26 AM | #4 | |||
11-07-2007, 02:18 PM | #5 | ||
If it drives ok just remove the lamp so it wont bother you again...
joking ha ha The starting problems may be the fuel pickup in the tank which is a very common problem on the Focus - when I say problem I mean 'feature' Mine does it whenever I park it nose up anywhere, have to crank it over and over before it starts. |
16-07-2007, 08:38 PM | #6 | ||
The engine warning light switched on in our Focus a few days ago, stayed on all night (we were ages from home) and then was off the next morning. We'll be getting ours looked it soon for a range of issues.
Current car: 2022 Escape st-line - Previous Fords: 2006 Focus, 2009 FG XR6T, 2009 Focus, 2012 Focus, 2016 Territory |
19-07-2007, 10:26 AM | #7 | ||
Well it's being repaired today, they are putting a new EGR valve in. If anybody wants any more info on what this is, I've found this site...
http://www.focushacks.com/index.php?modid=80
