Old 26-07-2007, 11:37 PM   #1
josh_hartman
Default Manual Conversion Question
Will a EL/EF manual conversion kit fit an au falcon?. if not what wont work?
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2007, 11:37 PM   #2
bodes-sh
no it won't. the gearstick is in a different position, it would be more up under where the radio is in an au
Old 26-07-2007, 11:44 PM   #3
josh_hartman
what if i put a au lever on it?
Old 27-07-2007, 09:17 AM   #4
bodes-sh
what difference is that going to make? where the actual lever sits on an au box is further back than an e series, so unless you want to extend the trans it won't matter, you would have to make up some sort of bent one
Old 30-07-2007, 09:29 PM   #5
squire
bellhousings are different, if anyone has a au i6 bellhousing for sale let me know
squire is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 01:11 AM   #6
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
yep, youll need the AU bellhousing, the rest should be ok from what Ive been told.
Ive got an auto6 bellhousing, no ideas on differences from manual though, but assume thier not the same
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 02:07 AM   #7
FGII-XR6
FGII-XR6's Avatar
also you will need an AU manual ECU
Old 31-07-2007, 09:16 AM   #8
StealthAu
So Josh, what happened with the BA auto you got?
Old 31-07-2007, 09:47 AM   #9
bomber
bomber's Avatar
PM sent
bomber is offline   Reply With Quote Multi-Quote with this Post
