Old 23-09-2007, 04:26 PM   #1
BlacklistedXR
Default Question About Lowering Rear of Au2 Xr8
i am having problems removing the springs from the shock absorber at the rear of my AU XR8. i have removed the shock absorber and springs from my car and cant seem to undo the nut that is at the top, middle of the rear shock monut. every time i turn the bolt the thread moves with it. is this supposed to do that? is that the bolt that removes the springs from the shockies?
cheers.
Current:
Built R32 GTR
520Hp ATW
AU3 Fairmont I6
Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo
Past:
2001 AU2 XR8 220 Manual
1/4 Mile: 13.8 @ 100MPH (161km/h)
Ford Falcon AU2 V8 Auto
1/4 Mile: 13.0 @ 107MPH (172km/h)
BlacklistedXR is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2007, 08:12 PM   #2
ronwest
All Bran = Regular Member
You'll notice that the top of the thread has couple of flats. Hold the flats with a spanner (shifter will do) while you undo the nut.
Make sure you are using a coil spring compressor as demonstrated in the link as the nut is under considerable spring tension http://www.swapace.com/items/66314/C...et_auto_tools/
Old 23-09-2007, 08:19 PM   #3
BlacklistedXR
ok, got it undone and have just finished installing them. cheers for the help ronwest.
Current:
Built R32 GTR
520Hp ATW
AU3 Fairmont I6
Past:
Old 24-09-2007, 12:15 PM   #4
BlacklistedXR
how important is it to use a spring compressor for the rears? i didnt use one and everything seems fine? i just tightened the middle bolt until it was really tight.
Current:
Built R32 GTR
520Hp ATW
AU3 Fairmont I6
Past:
Old 24-09-2007, 01:06 PM   #5
partie
the rears are fine without the compressor.
partie is offline   Reply With Quote Multi-Quote with this Post
