01-11-2007, 04:58 PM | #1 | ||
hey all im getting a noise from my au ute im thinking its the wheel bearing when im going in a strate line there is a rumble sort of noise when im going arond a left hand bend the noise is gon ........the steering is all good and feels the same as allways no shudder and smooth as ,,,do you think its the back wheel bearing????? how do i chek if its the back or the front?? :
01-11-2007, 05:00 PM | #2 | ||
All Bran = Regular Member
More likely front if the noise changes when turning.
Have a look through this and see if it helps. http://www.fordforums.com.au/vbporta...article&id=319 |
01-11-2007, 08:49 PM | #3 | ||
01-11-2007, 09:00 PM | #4 | ||
Sales Representative
Check your lower bushes... these can also make noises in straight lines...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
01-11-2007, 10:29 PM | #5 | ||
normally if you drive only a smooth road and swerve from left to right at around 60kph say you should be able to pin/point the noise (ie when turning left if you can hear it then its the r/h one and vise versa)
13-11-2007, 03:24 PM | #6 | ||
i have the same problem mechanic said its my left hand front wheel bearing. is it louder when u turn right? if so it cos of the left hand side is under more load when u turn right.
13-11-2007, 06:13 PM | #7 | |||
Formerly MR BAXR6t
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
19-11-2007, 09:08 PM | #8 | ||
i changed my left hand front wheel bearings(well hole hub) easy had no problems took 30mins. now its rolls better and is quiet
