Old 28-01-2008, 02:42 AM   #1
BFD83
BFD83's Avatar
Question Rear power windows
i was just wondering if anyone has added in power windows in the back and if so how much roughly did it cost ya etc. for some weird reason, front and rear power windows were only standard on the xr8's which is so stupid!
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 08:34 AM   #2
chief
FTF Club Moderator
chief's Avatar
I have added rear power windows. In order to do do you will need:
* New rear door trims (or you just have hole where the winder was)
* Power window regulators.
* Switches for the rear.
* The 4 way drivers control (unless you do not want control over the rear windows).
* Some wire.
If you get the switches from a Fairmont or above the switches will be illuminated. The concept is simple enough just a bit of work. Stav did the install on my car.
Albert Einstein:
Fords in the Park 2010
Old 28-01-2008, 10:00 AM   #3
bodes-sh
i also did it on mine, au forte, pretty simple, a lot more involved tho probably, because I did a 4 power window conversion as I didn't have any at all, I found the best place for the switches and regulators is ebay
Old 28-01-2008, 10:21 AM   #4
FGII-XR6
FGII-XR6's Avatar
you also need to replace the harness in the front drivers door as the connector is different
Old 28-01-2008, 11:18 AM   #5
JMO
JMO's Avatar
How much did it cost for all the parts, door trims included?
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 11:38 AM   #6
chief
FTF Club Moderator
chief's Avatar
Question
For the wiring and regulators and Stav's labour it was $400 to $500. Cant remember. I got the door trims and switches when I bought my Fairmont Ghia interior.
Albert Einstein:
Old 28-01-2008, 11:41 AM   #7
b2tf
not here much anymore
b2tf's Avatar
Hey Chief I know you told me before, but is there an extra wire for the illuminated power windows? I want to put the illuinated switch in the ute but be stuffed if Im adding any more wiring to do it!
2024 F150 XLT
Old 28-01-2008, 12:05 PM   #8
chief
FTF Club Moderator
chief's Avatar
The non illuminated switches have 5 pins on their loom, the illuminated switches have 7 pins. So you need to get different switches in order to get the globe holder inside the switch and add a positive and earth to the switch.
Albert Einstein:
Old 28-01-2008, 12:17 PM   #9
ST
ST's Avatar
I still want to do this to my car, is there anywhere you could just buy the lot?
2007 BF MKII XR6 CONQUER
ST is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 12:18 PM   #10
chief
FTF Club Moderator
chief's Avatar
Try FTG, they sold me the window regs and required wiring. I am sure you can get them to sell it as a kit of some sort.
Albert Einstein:
Old 28-01-2008, 12:24 PM   #11
b2tf
b2tf's Avatar
I could probably do that but I cant be bothered. If ever I come across a Fairmont drivers switch panel Ill give it a go.
2024 F150 XLT
Old 28-01-2008, 04:59 PM   #12
JMO
JMO's Avatar
Do AUII Futura's have the illuminated switches or are they non illuminated like the forte's?
Old 28-01-2008, 09:26 PM   #13
JMO
JMO's Avatar
Anyone know? I might be able to get some but have to know if they illuminate first.
Old 28-01-2008, 10:40 PM   #14
HOTC2R
I've got a set of 4 black door trims out of an AU2 75th Anniversary Futura which had power windows all around. Trims only as all the switches etc stayed in for the replacement leather interior from an XR8.
If anyone is interested, PM me.
HOTC2R is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2008, 07:18 PM   #15
chief
FTF Club Moderator
chief's Avatar
No idea. Surely someone with a Futura would know.
Albert Einstein:
Old 29-01-2008, 10:06 PM   #16
HOTC2R
Well the AU II 75th Anniversary Futura has illuminated switches, but I believe these came with the fairmont switches and other fairmont goodies
Old 29-01-2008, 10:34 PM   #17
b2tf
b2tf's Avatar
illuminated switches only on higher models like Fairmonts
2024 F150 XLT
Old 29-01-2008, 10:49 PM   #18
TICK4D-TAS
Club Moderator
And XR8's mine and my brothers XR8's both have illuminated switches.
TICK4D-TAS is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2008, 08:07 AM   #19
ClassicAU
My Futura has lights in the window switches also, but it's a Classic so i guess that means something :P
Well, it did for a while anyway, most of them are blown now! Don't suppose there is any way to fix them?
Evan
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2008, 06:48 PM   #20
Homes
Falcon Loving Hermit
Homes's Avatar
my futura don't have 'em (front only)...mine is only a regular series 2 futura though
AUII Futura 6 Cylinder - Still stock, except a few interior woodgrain bits
Homes is offline   Reply With Quote Multi-Quote with this Post
