Old 30-01-2008, 12:44 PM   #1
mark180227
mark180227's Avatar
Default Fixing Cracking Firewall
Hey All.
Time to get the cracked firewall fixed. I've got tsunamis coming in my car everyone time it rains and running out of adjustment on the clutch cable so its time to fix it.
Where abouts do I go to get this fixed, and can anybody recommend somebody.
cheers guys
mark180227 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2008, 02:34 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
I'd say any panel beater, how did it get cracked in the first place?
Old 30-01-2008, 03:37 PM   #3
james22
With da Warlords
james22's Avatar
Common manual ford problem since the effin EA lol. I hate pedal boxes and firewalls.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 30-01-2008, 05:58 PM   #4
JC
JC's Avatar
Originally Posted by mark180227
Hey All.
cheers guys
Buy some 1/4" steel plate, cut it to fit the spot you need and bolt it in.
Ford Performance Club ACT
Old 30-01-2008, 06:26 PM   #5
FGII-XR6
FGII-XR6's Avatar
AFAIK ford have a kit for this
Old 30-01-2008, 07:53 PM   #6
congo3sr
this bloke is joking.....I hope :
cheers George
congo3sr is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2008, 07:58 PM   #7
WindsorXR
FGII XR6, Focus Sport, XR
WindsorXR's Avatar
This happened in my EL XR6. I took it to a specialist joint and they said that there are actual kits you can get to fix this.It's basically a bit of plate with hollow tube for the cable to go through and it stiffens up the firewall and stops the wall from creeking every time you use the clutch or brake.
Living Ford dreams
2011 Purple FGII XR6
2016 LZ Focus Sport
BA XR8 Build Thread (SOLD)
1966 XR Falcon Build Thread
WindsorXR is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2008, 08:47 PM   #8
superroo
You can't stop the signal
superroo's Avatar
cheers George
Essentially, no. There also needs to be tube welded to the plate.
Here is my quick fix to the crack that i had around the tub. It's a doddy job that i will get round to eventually doing properly, using a bigger sized plate, and bolting it to the fire wall.
It works, but i'd like to have something over kill in there, so i know it won't be a problem
Old 30-01-2008, 11:43 PM   #9
kcej
2mny projects 2 lttl time
Since the EA my bottom........had this prob in my very first XF I ever bought, and I'm sure that wasn't the first manual ford to have it lol
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2008, 08:02 AM   #10
james22
With da Warlords
james22's Avatar
I stand corrected lol. EA gave me the shits something chronic. 2 Pedal boxes and a firewall job. What a PITA
Windsor Warlords
AU III XR-8220
Old 31-01-2008, 02:42 PM   #11
loxxr6
XB in parts...
loxxr6's Avatar
Exactly what I was told but several dealers have said to me they know nothing about it.
Be careful who you get to do the repairs. One joint wanted to pull my whole dash out to do it...
Old 12-02-2008, 09:54 PM   #12
VCT_XR6_UTE
VCT_XR6_UTE's Avatar
Just found out i need this job done to my ute, pedal is really hard to push and the pedal is bent all out of whack, anyone know a rough cost for this job?
VCT_XR6_UTE is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2008, 10:16 PM   #13
philstoj
philstoj's Avatar
Before you go and rip the cars apart and weld plates in etc, before you do anything, find the source of the leak first!! Will save you plenty of $$$$$$$.
I have had this problem up untill recently...
I have found the leak and sealed it, cost peanuts and didnt take long to fix.
I too thought i had a cracked firewall, broken pedal box (in fact its a bent clutch pedal) so i stripped out the car, removed the wiper motor and arm assembly, got the missus to spray water in the cowl (bottom of windscreen) and found the culprit, a dodgey spot weld, a hole where a spot weld should have been, easy fix, fill it with urethane ( i had some on hand ) job done, no more leaks.
So before you go out shelling thousands to get something welded that doesnt need to or isnt broken, check it out first, and then fix it.
Old 12-02-2008, 10:19 PM   #14
philstoj
philstoj's Avatar
Change your pedal and pedal box, replace your clutch..
How the hell do you change gears?
Old 12-02-2008, 10:28 PM   #15
Mechan1k
Mechan1k's Avatar
After seeing this being done ... I can safely say it is easier to get this work done on the AU compared to the EL I just witnessed.
The EL need the dash to be unbolted but not completely removed. The AU don't need the dash to be touched.
It's the only time I can safely say "Thank God I drive an auto".
Old 22-02-2008, 07:51 PM   #16
LPGUTE
LPGUTE's Avatar
my firewall look like it been fix but....i have a question....dose the plate in the picture or the cable suppose to move? because mine is...
the plate look like it had not been welded.
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2008, 10:33 PM   #17
mark180227
mark180227's Avatar
can anybody suggest any places in melbourne to get the firewall welded up etc?
Old 16-03-2008, 07:07 PM   #18
mark180227
mark180227's Avatar
anybody?
Old 16-03-2008, 08:24 PM   #19
GK
Walking with God
GK's Avatar
Any decent panel beater could do it. Choose one that you know and they'll be able to weld up something for you no worries.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 31-03-2008, 02:40 PM   #20
loxxr6
XB in parts...
loxxr6's Avatar
anybody?
Just print the pics off in the thread and take it to any panel beater. You'll be fine.
Old 11-04-2008, 03:37 PM   #21
mark180227
mark180227's Avatar
Took the car to Ford the other day just to see what they thought about it. They said they would have a look at and get back to me. So i left it with them for the morning, upon returning this is what they presented me with.
Clutch Kit
Clutch Cable
Clutch Pedal Box Assembly
Flywheel Machine
Cluth fork Bush
Firewall to be Welded Both Sides
Dash Needs to be Removed
Brake Master Cylinder, Booster, Firewall Insulation and ENGINE require to be removed to Repair Firewall
Parts Cost @1209.90
Labour @ 15.5 Hours $1670.90
Welding and Reinforcement Repair $250.00
Tow Truck Transport from Panel Shop $240.00
For a Total cost of 3370.80.
found this quiet interesting.
Old 11-04-2008, 03:45 PM   #22
blueoval
Critical Thinker
blueoval's Avatar
Take that list (erase the pricing) to a trusted mechanic and get another quote.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2008, 03:57 PM   #23
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Hi there mate, i owned a ed xr6 5 speed with headers from day one i bought it, i had traveled over 150.000 klm's in it, the current owner has done another 150.000klm's in it with not a problem with the fire wall.
why you ask?
dont skimp on replacing clutches & cables, as soon as the clutch/cable feels hard or about 60-100.000 k's get rid of it.
piece of mind.
Or what i do to customers car's is i bolt a 1/4 inch steel plate with the a cable hole, mounted on the inside to stop flex. Also get your pedal box welded as there spot welded from fomoco.
cheers mick.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 09:05 PM   #24
Night
You would think that this is a design defect that Ford should have to fix. How come they are allowed to get away without recalling the cars for?
Night is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 09:27 PM   #25
mark180227
mark180227's Avatar
thats exactly why i rang Ford and complained about it. I said the same thing, that its a design fault in the car and Ford should be responsible for fixing it. But true to reputation, customer care treat you like and dont want a bar of it. It's rediculous.
Old 17-04-2008, 03:30 PM   #26
loxxr6
XB in parts...
loxxr6's Avatar
Clutch Kit
Clutch Cable
Flywheel Machine
Cluth fork Bush
Parts Cost @1209.90
I'd tell them to do what a duck can't. Shove their bill up their ar$e.
What did you end up doing ?
Old 17-04-2008, 09:03 PM   #27
Night
As dumb as this sounds, I would think that it could be a major defect not only because of structual reasons but because of engine fumes entering the cabin. I can't see how the goverment allows ford to get away with this as I'm sure if a cop pulled you over and saw a rubber plug missing in your firewall he would defect you for that very reason. How come ford don't have to recall their cars?
Old 17-04-2008, 10:04 PM   #28
mark180227
mark180227's Avatar
got in my car and drove off.
no chance in hell of me paying that.
I know my whinging isnt going to do much, but i think Ford should be accountable for such a defect like this. It has effected so many cars on this forum, let alone any body else in the general public.
