07-04-2008, 09:58 AM | #1 | ||
As the title says, I have noisy fan belt. Nothing over the top or particularly wrong with it (that I know of) but there is a distinct sort of whining/grinding noise coming from it.
My brother in law has an XR8 and I haven't noticed any similar noise coming from his front end (I might be too busy listening to the growling 8 though ) I just wanted to know if anyone else has had this and if stopping it is as simple as greasing up the wheels? |
07-04-2008, 10:11 AM | #2 | ||
Sales Representative
Silcon spray helps the grip... but it could be on its way out... check for cracks and chips in it...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
07-04-2008, 10:12 AM | #3 | ||
The Origional, The Best
strangly enough, on my old laser, i used to run a candle around the belts, with the car running, just be careful not to catch ur hand on the belt. stopped the noise for a good while.
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
07-04-2008, 10:17 AM | #4 | ||
It sounds more like a 'rusty wheel' does that still leave a failing belt as a possible culprit?
Where do you spray the silicon spray? With the candle wax, I'm guessing you mean on the inside (grooved side) of belt? |
07-04-2008, 10:17 AM | #5 | ||
XR6 Tragic
I wouldn't recommend a candle, however if you want to try lubricating the belt you should buy a cheap grease stick, then touch that to the belt while its running.
07-04-2008, 10:34 AM | #6 | ||
Inside or out?
07-04-2008, 10:50 AM | #7 | ||
inside
07-04-2008, 10:51 AM | #8 | ||
I'll give it a go later on.
I'll let you know how it goes. |
07-04-2008, 10:53 AM | #9 | ||
[QUOTE=JMO]It sounds more like a 'rusty wheel' does that still leave a failing belt as a possible culprit?
Could be one of your pulleys. My powersteering pulley is noisey.
07-04-2008, 11:25 AM | #10 | ||
Know of a fix, apart from buying a new one?
07-04-2008, 03:02 PM | #11 | ||
My idler pulley is on the way out. It's very noisy. If I lubricate the middle of it with some WD40 or general purpose oil it shuts up for a few minutes, but then is right back to making a racket.
I read that you can't buy the pulleys separate, but there are a couple of ford parts that do the job OK. A google might turn up more. Matt. |
07-04-2008, 04:31 PM | #12 | ||
To see which pulleys are dry you need to take off the belt
Then just spin them, you will hear which one is making the noise Usually they get dry as the grease goes hard If the idler pulleys are dry it is easily fixed, take them off, carefully pick out the seals with a sharp instrument trying not to damage them, clean the bearing and repack with new grease, push seals back in. New bearings can sometimes be pressed in but often they just shatter, you can buy new pulleys about $30 each, or if the whole idler thing is broken (these can squeek too when the grease dries up) it is about $100 from Ford but has 2 new pulleys on it. |
07-04-2008, 04:46 PM | #13 | ||
Dirty ute club member
Just before I bought the ute the idler pulley was making noise and the bloke replaced it. So that much mean you can buy the pulley doesnt it? The belts making a bit of noise again/still so I need to do something about it too.
2000 AU2 XLS Daily 1992 Toyota Celsior: 4ltr quad cam goodness UZN106 Hilux: Absolute mongrel bitsa also with 4ltr quad cam goodness...Forced induction in the planning |
07-04-2008, 05:55 PM | #14 | ||
There are aftermarket pulleys available as I fitted a new idler pulley 2 weeks ago. Cost me $26 for the pulley and took about 1/2 an hour. Only annoying thing is I should have bought the tension pulley at the same time as it is also noisey but couldnt pick it over the racket of the idler pulley.
07-04-2008, 10:16 PM | #15 | ||
The pulley in front of the power steering fluid reservoir has a rusty looking centre. I'm guessing that is the likely culprit.
How do I loosen the fan belt and remove this wheel or one of the others for cleaning and regreasing? How do I put it back together and retighten the fan belt? |
07-04-2008, 11:43 PM | #16 | ||
Loosen the fan belt by putting a 3/8 socket into the square hole on the double idler pulley (Assuming its a 6). You might need a piece of pipe over it to get leverage. It is spring loaded so push against the spring (towards passenger side) and flick belt off the water pump, (make sure you have the sticker on the underside of the bonnet or know how it goes back on)
If it is the power steering pump pulley, it is a take off the pump and press on a new pulley job. Gently wiggle it from side to side if there is any movement around the centre shaft that could be the problem If its the idler pulleys (normally is) there are 3 10mm bolts to undo, then a 15mm?? bolt to take the pulleys off the idler part. |
08-04-2008, 11:03 AM | #17 | ||
Yeah mine were squealing as well then the belt snapped, got the car towed home, replaced the idler pulleys by lube mobile, took him an hour (lets not talk about the price). Then found that the water pump puller was dropping the belt off becuase the old belt had melted onto the pulley. Had to replace the whole water pump because the pulley is pressed on. It runs ver nice now, very quiet, all I have to do now, If i want to is the crank wheel and the power steering one but they are still very quiet after 300 000kms. i would just replace them if they have done alot of kms for piece of mind.
There's my two cents |
08-04-2008, 11:20 AM | #18 | ||
Can you pick up the pulleys from supercheap, repco, burson's etc?
17-07-2008, 05:54 PM | #19 | ||
I just replaced the idle and tension pulleys. Most of the sound is gone but there is still some more noise coming from one of the other pulleys. They are:
1. AC compressor 2. Water Pump 3. Power steering 4. Alternator 5. Crank shaft What is needed to get each of them off and put them back on? They appear to have to be pulled but how do you get them back on? The crank shaft pulley is almost completely rusted looking and looks like it has a bolt in the centre of it holding it on. Is it a bolt off bolt on job? |
17-07-2008, 08:12 PM | #20 | ||
the harmonic balancer (crankshaft pulley) shouldn't be making noise...did you replace the belt at the same time? if anything it is more than likely the water pump
17-07-2008, 08:17 PM | #21 | ||
god damn it why is everyone dodgy LOL. i put all new belts on my EB. tightened to specs. the too much load on the alternator when using high beams, heater, stereo with subs etc makes it squeal so then as a last resort i put on some belt grip spray. haven't had a problem since
17-07-2008, 08:54 PM | #22 | |||
17-07-2008, 09:33 PM | #23 | ||
well i didn't see AU anywhere so i was taking a guess
17-07-2008, 09:49 PM | #24 | |||
Back on subject, while the car is running carefully spray some crc or similar around the centre of the pulley you think may be the cause. If sound disapears or changes you know what needs replacing. Also grab some belt grip from supercheap or the like and spray both sides of the belt while the car is running. |
18-07-2008, 07:16 AM | #25 | ||
ohhhhhh my bad. i just clicked on the thread. umm belt grip yes. crc no. i sprayed some crc on a belt at work. caused it to slip off and shred the belt.
18-07-2008, 07:35 AM | #26 | |||
