Old 14-04-2008, 10:57 AM   #1
5L
[ 5L ]
5L's Avatar
Default IRS rear shock mount
for a while now my car has had a clunk when turning corners at low speeds, i though it might be the diff or the tailshaft but i read up on the forum about it and im fairly sure now it is my rear shock mounts.
i went out this morning and came across this
drivers side im guessing this is a little worn but generally what they are suppose to look like.
passenger side, this one has collapsed alot and it actually resting on the body of the car.
to fix these do you just drop the shocks put the new shock rubber mounts in and put the shocks back up? how much roughly would it be to get this fixed?
www.ignitionimages.com
Old 14-04-2008, 11:05 AM   #2
5L
[ 5L ]
5L's Avatar
also do you know if this could also be the problem for my diff bounce. it sounds like the diff is hitting the floor, maybe its the shock hitting the mount.
Old 14-04-2008, 04:51 PM   #3
philstoj
philstoj's Avatar
The diff cant hit the floor as its mounted in the cradle and doesnt move, the drive shafts move up and down though, so does the rear struts so looking at your pics, it will definatly be the strut hitting.
Old 14-04-2008, 04:56 PM   #4
5L
[ 5L ]
5L's Avatar
no worries cheers
Old 14-04-2008, 05:57 PM   #5
blackers10
blackers10's Avatar
they look upside down mate??
the metal "washer" type bits anyway..
can anybody confirm??
Old 14-04-2008, 06:02 PM   #6
5L
[ 5L ]
5L's Avatar
well its all standard, suspension has never been worked on. unless ford messed up.
Old 14-04-2008, 06:10 PM   #7
philstoj
philstoj's Avatar
Just had a look at the workshop manual and looks like in the diagram that they do sit opposite to what they are in these pics, so looks like they have been changed atleast and not installed right.
Old 14-04-2008, 06:11 PM   #8
5L
[ 5L ]
5L's Avatar
ah ok fair enough so someone has messed up along the lines.
Old 14-04-2008, 06:11 PM   #9
5L
[ 5L ]
5L's Avatar
can anyone get a pic of there so i can compare
Old 14-04-2008, 06:12 PM   #10
blackers10
blackers10's Avatar
well they would be removed to change shocks so presumably thats when its been played with...
which is why they have sort of cut into your rubber surround mate
the busted ones usually just move up and down not like that..
they are pretty cheap to replace if you fit them your self
good luck
Old 14-04-2008, 06:13 PM   #11
5L
[ 5L ]
5L's Avatar
no worries cheers, so basically that washer/cup thing just gets turned around the other way.
Old 14-04-2008, 06:15 PM   #12
5L
[ 5L ]
5L's Avatar
so can anyone give me a simple write up on how to do the job.
i was thinking that the shocks would need to get dropped, and then the rubber fitted.
Old 14-04-2008, 06:21 PM   #13
blackers10
blackers10's Avatar
for the rears.. undo the 4 nuts on the top there in the photo
and the bottom shock bolt
and from memory theres 1 other bolt you need to undo to remove them i just cant for the life of me remember which one..
2 people is alot easier too
good luck mate
Old 14-04-2008, 06:23 PM   #14
5L
[ 5L ]
5L's Avatar
ah ok so the whole shocks need to be taken out for the job
Old 14-04-2008, 06:25 PM   #15
blackers10
blackers10's Avatar
yep
$90ea approx from ford for a replacment upper strut mount
the top piece is 2 halfs.. 1 is the spring seat which slides into the bit you see there
just bang it on the ground a few times or get a mate to pull the halfs apart and then just slide new one on and re install
Old 14-04-2008, 06:32 PM   #16
5L
[ 5L ]
5L's Avatar
no worries cheers.
