Old 14-04-2008, 07:47 PM   #1
DWag
DWag's Avatar
Question fuel filter for au2
i want to change the fuel filter ion my au2 ute. Any suggestions on the best way to do it?
I havent changed one since my old xf.
Also where is it located in the au2 6cyl?
Thanks in advance for the help :
DWag is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 07:51 PM   #2
poolkeeper
Its Resonating!
poolkeeper's Avatar
Located on the passenger side, inside of the chassis rail.
Is this to help your hiccup problem?
Cause I changed the fuel filter, didnt stop my problem.
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 07:54 PM   #3
DWag
DWag's Avatar
yeah it is, i bought a fuel filter and some leads. i figure do the filter first, then the leads if no success.
Old 14-04-2008, 07:55 PM   #4
DWag
DWag's Avatar
excuse my ignorance, but what is the chassis rail?
Old 14-04-2008, 07:59 PM   #5
fordon
fordon's Avatar
the steel rails on each side of car that runs from front to rear
fordon is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 07:59 PM   #6
b2tf
not here much anymore
b2tf's Avatar
big long bit of metal that the car is basically built on.
2024 F150 XLT
Old 14-04-2008, 08:02 PM   #7
DWag
DWag's Avatar
i did think that, thanks guys!
so do i just unplug the old one and plug the new one in? i was just thinking today that if i do that i might get air in the fuel lines.
Old 14-04-2008, 08:31 PM   #8
poolkeeper
Its Resonating!
poolkeeper's Avatar
Mine had 2 nuts to undo, some have this weird clip thing but with 1 nut.
You take the fuel pump fuse out, start it and wait for it to die, then give it one more turn.
Replace filter, then put fuse back in and just do a few quick on & off motor running.
Old 14-04-2008, 08:41 PM   #9
DWag
DWag's Avatar
thanks heaps mate, you have been very helpful
Old 14-04-2008, 10:25 PM   #10
bodes-sh
also, usually if you leave it over night before you do it then not much fuel will come out anyway, then afterwards just turn the key on and wait till the fuel pump stops pumping, then it should start and run as normal
Old 15-04-2008, 06:43 PM   #11
GK
Walking with God
GK's Avatar
This may help.
GK
Changing Fuel Filter
http://www.fordforums.com.au/showpos...3&postcount=37
Now gone!
On LPG
Want a Full Life? John 10:10
