17-04-2008, 03:41 PM | #1 | ||
Just wondering my AU has now done 200.000 Klms and my belt has small cracks right thoughout the small rubber V's should I now replace the belt
Thanks Dennis |
17-04-2008, 03:54 PM | #2 | ||
i would say yes
better to be safe then stuck in the middle of nowhere without one..
17-04-2008, 03:54 PM | #3 | ||
It couldn't hurt, but if you're short on cash then consider the following.. If the lines run across the V's it's not too bad, if they're along the V's or are visible from the other side of the belt then it's worth doing now.
17-04-2008, 03:54 PM | #4 | |||
All Bran = Regular Member
According to Gregory's:- "Small cracks on the ribs are acceptable, however if adjacent ribs have cracks or missing sections, the belt should be renewed" |
17-04-2008, 04:00 PM | #5 | ||
do you recall the length/part number of the belt ronwest?
also was it VCT or not?? and did you notice if there was a difference in length in "the book" between VCT and intech?
17-04-2008, 04:23 PM | #6 | |||
VCT and non-VCT are different but I can't see a ref in the book. I'll have a better looksee a bit later. |
17-04-2008, 04:31 PM | #7 | ||
awesome cheers
18-04-2008, 12:59 PM | #8 | ||
I would have replaced it 100000kms ago
They can do a lot of damage if they fail Check your idler pulleys too, they will be dry, very easy to pull off and regrease. |
19-04-2008, 09:29 AM | #9 | ||
Thanks all will replace today
Cheers |
19-04-2008, 12:25 PM | #10 | ||
http://www.gatesaustralia.com.au/ these sound alright not sure how much dearer they are but |
19-04-2008, 06:02 PM | #11 | ||
Good thing you brought up the subject. I will check my belt ASAP.
. . Rob Ewart Bog standard silver BF Wagon, except for the Elvis doll , on gas. Victorian Rock'n'Roll Dance Association www.VRRDA.com.au 2015 Victorian Rock'n'Roll Dance State Championships 23 May 2015, Furlan Club, Thornbury |
19-04-2008, 07:15 PM | #12 | |||
Matt. |
19-04-2008, 09:35 PM | #13 | ||
thats quite cheap for a "performance belt"..just make sure its that exact belt
19-04-2008, 11:49 PM | #14 | ||
