16-06-2008, 09:00 PM | #1 | ||
Teh Baest
Up on ebay
http://search.ebay.com.au/_W0QQsassZgurwinder351 claims around 18rwkw with both of them. Would it be worth the investment? It was for an EF, but never got fitted. Will probably end up at around $600 for both of them. So about $30/rwkw not bad What does polishing the intake manifold and throttle body actually do? Does it just decrease the resistance to airflow or something?
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
16-06-2008, 10:38 PM | #2 | ||
I dont see 18rwkw from that. Buy it and find out?
I can't see you netting any gains from any throttle body work.(unless force fed) As for the manifold well.. I doubt it. The only real way to make power over the standard manifold and throttlebody set up is to go for a 6 individual throttlebody setup. But at $4000+ makes it out of reach for most. |
17-06-2008, 05:38 PM | #3 | ||
im currently winning the bid for the Intake manifold so ill let you know if i win and how it goes...
Duel Fuel, 3.9 diff gears, s/steel cat, pacemaker extractors, 2 1/2" sports exhaust, K&N pod filter in airbox, 3" stainless pipe from airbox : NOW BLUEPOWER TUNED!! : : MY CAR!! :
17-06-2008, 07:16 PM | #4 | ||
Damn i was outbid! should i go up more??? What should i be paying for something like this??? 32mins left!!!!!!!!!!!!!!!
17-06-2008, 07:26 PM | #5 | ||
rofl copter
the TB is worth it, 200 bucks to get that done from someone (thats what ive been quoted, the manifold aint worth it, see what snort have on an upper manifold plenum ;)
GQ patrol.
.... thats all |
17-06-2008, 07:29 PM | #6 | ||
hmmm yeah u may be right...i might let this one go..sorry to hijack the thred ayeyew!!!! :
17-06-2008, 07:31 PM | #7 | ||
MADED.6
hey josh the carby joint shaves the carbys to make them bigger for $120 and grechie did it and felt a difference so might be worth it.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
17-06-2008, 08:16 PM | #8 | ||
Highway Taxi
SS Inductions stoped making the modded throttle bodies for the AU I6 because there was no power gain.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
17-06-2008, 08:24 PM | #9 | |||
A bigger throttle body MIGHT gain something on a heavily worked 6, but not on a basic modded 6. So it makes sence not to bother with one unless your going for every last rwkw possible. |
