Hi folks,
While I was away for two weeks, the old man had to disconnect the battery because the panic alarm would randomly go off. Before I came back he put the battery on charge and when I got back all was good. Today I had the alternator replaced. The battery light had been going on and off for the past few nights and this morning it just stayed on. Picked the car up and bought it home and then the panic alarm saga started all over again. Have taken the battery out and am giving it a 12 hour charge. Does the panic alarm randomly going off indicate anything else? All entry points were secure and interior lights off when it kept wailing away. Cheers
06/01 AUII XR8 |
64 Deluxe 4 door
![]() Join Date: Jun 2007
how close are the remotes, maybe one of them has a dodgy switch, rather than the car
XM Deluxe FG XR50 BA Pursuit Ute |
Spares are hidden away. Checked all buttons and they're not sticking. Maybe a low battery in one of the remotes?
06/01 AUII XR8 |
For those interested all was fine until the panic alarm started going off again tonight. Check both of my fobs while it was going off and noticed on the spares the red light was flashing. Took the battery out of it and now it appears all is good (touch wood). My guess is the battery is cactus. So far so good, no late wake up calls.
06/01 AUII XR8 |
#5 | |||
Back to Le Frenchy
I remember reading here somewhere that when the battery on a remote starts to go flat and is within range of the car it will set the panic alarm off. Don't know why, seems a pretty bloody annoying way of letting you know if you ask me.
Appears to be programmed to go off only in the middle of the night too.
06/01 AUII XR8 |
i had a similar problem with my dad's fairlane where i had borrowed the car and was parked at a mates workshop, anyway the panic alarm kept going off, and i kept stopping it, until it got to the point where i walked and pulled the battery terminal off. Anyway the next day im at the same w/s in the same car and its happening again, im like ha? what the? at which point i went and grab the spare keys from the mechanic next door who was having a good old giggle.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
anyone know if you can deactivate the panic alarm ? it is a PITA you sit down with a few things in your pocket and off it goes it is a function i can do without
[SIGPIC][/SIGPIC]
Are you sure about that?
This happened to me. Replace the remote batteries and it will fix it.
It is a real pain when it goes off at 1 or 2 in the morning.
When I grow up, I want to be half as good as you THINK you are. |
