Old 09-08-2007, 05:21 PM   #1
J.O
Default Water in headlight
Anyone know how to get water out of a headlight? It's sort of frosted up with drops all over the inside. It's veeeerrrrrry annoying!!! : Especially as the rest of the care is nice and clean.
Old 09-08-2007, 05:26 PM   #2
FGII-XR6
FGII-XR6's Avatar
take it out pour a bit of metho is and swish it around. tip out metho and leave in the sun for a few hours and it will dry out quickly
Old 09-08-2007, 05:48 PM   #3
Fairlane
V8 Powaah
Fairlane's Avatar
We the only thing i can suggest is an im not 100% it will work for the AU headlight. But my EL had leaky indicators on the front. I removed the indicator, left it in the summer sun for a few hours, sealed it up on the outside at the back with 'Automotive Silicon', put here back in and never got any moisture in it from then on.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2007, 06:45 PM   #4
J.O
Anything that doesn't need the light to be removed?
Old 09-08-2007, 06:49 PM   #5
josh_hartman
i had the same problem. remove the rubber and pull out your parkers and then drive with lights on and the water goes away. you need to take the parker out though so it has someway to escape
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2007, 09:26 PM   #6
J.O
Thanks. I'll give it a go and let you know how it works out.
Old 10-08-2007, 07:59 PM   #7
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Used a hairdryer to dry mine out, take out globes and poke in hole
Silastic all joins so it doesn't happen again, although to do ALL joins you gotta take it out or the bumper half off anyway, maybe you'll be lucky and the leak will be in the top half, to find leak put spray n wipe (or similar) around joins and blow some air into light, leak will bubble.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2007, 08:15 PM   #8
AU dude
Flying high...
AU dude's Avatar
I used to have the same problem, just remove the rubber at the back of the headlight and plug the loom back in. Went away in like a day of driving....
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 12:17 AM   #9
Fordmuscle1965
Fordmuscle1965's Avatar
Has anyone had this problem with an AU Fairlane and if so what plan of attack did you have?
Current Rides
Mystic FG Turbo, 19" GTP's
XK sedan stock.
1989 F250 V8
Previous Rides
Black G220 Dumped
93 Black ED XR6
04 Territory, 20's, Black, Bling
94 NC Barge, Dumped, 17's
93 EB S, Dumped, 17's
86 Barge, Dumped, 17's
86 Cruiser of Land!
86 XF Wagon, Bull Bar, Raised, Salt Lake cruiser!
82 XE Sedan, Dumped, 15's
74 XB Coupe, 18's
73 XB Sedan
61 XK Wagon, old school.
78 Cortina.
Projects
65 Zephyr, Tubbed, 289, Simmons
65 Mustang LT Project
Fordmuscle1965 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 12:31 AM   #10
JC
JC's Avatar
No, but the cure would be as above. A Fairlane is no more or less prone to these things than any other ford (I own a problem riddled NF - well, it was problem riddled, but now is mostly fixed).
Ford Performance Club ACT
