Old 18-08-2008, 08:54 AM   #1
Mont5.0
Mont5.0's Avatar
Default Snorkel scoops.
has anyone seen/used/or made one of these? do they work?
http://cgi.ebay.com.au/AU-non-XR-Fal...QQcmdZViewItem
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 08:56 AM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
That ad is confusing! Is it the scoop and snorkel, or just the scoop?
Old 18-08-2008, 08:59 AM   #3
Mont5.0
Mont5.0's Avatar
just the scoop
Old 18-08-2008, 09:42 AM   #4
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
it's just a piece of tin you can make one yourself.
re-directs airflow that would otherwise not go directly into the snorkle,
i really doubt that you would have a noticable difference under normal driving conditions but every 1rwkw counts...
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 11:07 AM   #5
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
They want to charge you 35 bux for THAT??
Ad seems dodgy as...
CAI intake mods are effective, but that little scoop wont help with the ramming effect of the intake. If it was to work it wouldnt do much untill higher speeds anyway...
I believe a wide, open mouthed intake with a big throat and un-restrictive path is a better investment, and stick with that.
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 01:15 PM   #6
AU3XSR
First time Falconless
AU3XSR's Avatar
I made one using aluminium plate and cut out a section from the top of the grill frame. Prob does sweet FA around town and prob not much more at normal highway speeds, but who knows...like Fairmont4.0 says, every rwkw counts :-)
2008 FG G6E
Previous:-
2012 Fiesta Metal | 2001 AU2 XR6 | 1994 EF Fairmont | 2010 FG XR50 Ute | 2006 BF Typhoon | 2002 AU3 SR
AU3XSR is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 01:58 PM   #7
robjunior
[QUOTE=XR6_4EVA]
CAI intake mods are effective, but that little scoop wont help with the ramming effect of the intake. If it was to work it wouldnt do much untill higher speeds anyway..QUOTE]
i think you are on the mark as i made up a piece of metal that you are talking about on my s1 tickford duel fuel and on gas it was ramming to much air into the balance pipe at 80kph and up causing it to lean out/misfire.soon as i took it back off problem when away.i believe it does ram more air in,but if it gives you any power gains im not sure.
robjunior is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 02:15 PM   #8
aye you
The Origional, The Best
aye you's Avatar
i smell
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 10:33 PM   #9
Mont5.0
Mont5.0's Avatar
yeah i already have the larger xr8 snorkel, and most of my k's are motorway,
so i might give it a go. seems easy enough to make.
Old 19-08-2008, 12:30 AM   #10
dreadly
Make one... I did and i reckon it works well highway kms makes a difference and get a typhoon/xr6 turbo intake cut a hole and fit it upside down and remove your lense protectors (i have an xr8) and that scoop with the new intake behind the lights, and a k&n pannel filter.. and you'll notice that a bit hey
dreadly is offline   Reply With Quote Multi-Quote with this Post
