Old 23-08-2008, 06:37 PM   #1
XRLNT-8
Monsoon SIII XR8 220
XRLNT-8's Avatar
Default Road Noise PLEASE HELP!!
Hi all,
This is going to be very difficult to explain but I will do my best and would appreciate any feedback greatly as this is really p$$ing me off.
Car: AU XR8 Series 3, Auto, IRS Rear end
Problem: When driving between 50 and 70kph, a noise in the cab has developed which sounds like a tyre has uneven tread (rythmic sound with each rotation). I have removed each wheel one by one and replaced with a wheel I know is OK, road tested and this did not change the sound at all.
I have tried coasting in neutral, applying handbrake, disengaging handbrake, driving with brakes on, all at speed and no effect on noise.
Is there anything else in the driveline which could become out of balance and make this sound ie. wheel bearings, diff, driveshaft, cv axles on IRS??
Cheers,
Simon
XRLNT-8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2008, 06:52 PM   #2
AU1XLS
AU1XLS's Avatar
Wheel bearing?
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2008, 07:44 PM   #3
bodes-sh
yep, i'd say wheel bearing too
Old 23-08-2008, 08:02 PM   #4
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Yep id go wheel bearing too. I had similar problem not long ago. Does it get any worse while turning, when putting more weight on one side. That might narrow it down a bit?
Current car
94 ED Fairmont 5L in Burgundy
Fords ive owned-
2010 FG XR6 5 speed auto in Mystic
81 XD S-Pac 302c 4sp manual
78 Yellow TE Cortina Wagon 4.1L
92 Green EB Fairmont GT replica
01 Black AU XR8 II Manual
04 Rapid BAII XR6T 220rwkw
04 Mandarin BA XR6T 247rwkw
07 BF II XR6T 385rwkw
1980 ZJ Fairlane 302c
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2008, 10:15 PM   #5
Bolly
Bolly's Avatar
Agree with Wheel bearing as well.
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 10:43 AM   #6
EvilChief
Boost Addict
or dry CV joints :p
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 24-08-2008, 01:15 PM   #7
honer
Back to N/A land
Dry CV joints ? Their sealed within the boot.. If there is a split boot then they are buggered.
But yes I'd go with Wheel Bearing
honer is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 01:27 PM   #8
FORD5
FORD5's Avatar
I agree with wheel bearings
FORD5 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 03:01 PM   #9
EvilChief
Boost Addict
my point, it doesnt say anywhere that the boots arent split and i didnt feel like repeating wheel bearing like everyone else, i was just giving another option that can create same type of noise
N12 Pulsar - sold
Old 24-08-2008, 05:28 PM   #10
dreadly
Is it coming from the front or rear? jack it up and give the wheel a riggle, See if its your bearings... If not get it on a hoist and turn and move the wheel if you get some squeaks id say it'd be your lower/ upper control arm bearings?
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 06:00 PM   #11
scrivens
quarter pane
scrivens's Avatar
Have something similar in passenger front; rhythmic thump which sounds like a tyre out of round. I swapped it with the other wheels and it still happened so put it up on the hoist and checked the bearings, brakes and so on - all fine. Mentioned it to a tyre guy; he took it for a spin and he reckons it is caused by the tread pattern on the Firestone tyres now that they are down to about 70% worn. (All the wheels have the same tyres and they've been rotated so the wear is pretty much the same on all.) Awful tyres, btw.
scrivens is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 08:59 PM   #12
XRLNT-8
XRLNT-8's Avatar
Thanks heaps for the replies,
I did a fair bit of driving today and tried swerving left to right at speed and it made the noise less apparent when veering to the right.
When I swapped out each wheel yesterday I did rotate the front wheels by hand and checked for shimmy but all seemed ok (probably not a very good test as there is no load on the wheel bearing)
I guess that I could reasonably suspect the front driver's side bearing or either of the rears, can they be inspected without replacement?
Cheers,
Simon
Old 24-08-2008, 09:48 PM   #13
dreadly
Huh? lol just got out to each wheel with the car on the ground grab each wheel and try to move it- up and down then side to side if you have movement its a bearing, If you dont get any movement jack it up you'll need a trolley jack and move the wheel side to side if you get some squeaks... Its most likely your lower control arm bearing...
I had to replace mine it fixed it 9/10 it'll be your tyres and cabin noise- kinda sound similar to a diff whine, but coming from your passanger firewall.
Old 24-08-2008, 11:46 PM   #14
ronwest
All Bran = Regular Member
A few tips on diagnosis here:- http://www.fordforums.com.au/vbporta...article&id=319
Old 25-08-2008, 09:15 AM   #15
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
I'd say its wheel bearing, i had the exact same noise in my car and i just had the bearings replaced and now its all sweet! Warning, dont hesitate to go get them checked asap, mine were turned into dust and i was very close to a siezed wheel.
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 12:35 PM   #16
Pistonbroke
One word: Wheel Bearing.
Pistonbroke is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 12:54 PM   #17
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
THATS TWO!
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 01:39 PM   #18
XRLNT-8
XRLNT-8's Avatar
Just rang ABS (auto brake service) they quoted $285 per side to fit new hub. I think I will do it myself using the brilliant how to from Ron West.
Cheers,
Simon
Old 26-08-2008, 08:38 PM   #19
XRLNT-8
XRLNT-8's Avatar
Success!! :
I replaced the driver's side hub today and the noise has gone.
Thanks to all who gave advice, you were spot on.
Here are some points of interest I thought I'd share as it may help those who tackle this job in the future.
1. Print out the How To guide by Ron West http://www.fordforums.com.au/vbporta...article&id=319 and read it carefully.
2. None of the Auto shops had a 35mm socket. I ended up borrowing one from a mechanic.
3. I jacked car up and tried rocking wheel from top to bottom but it felt totally sound even though bearing proved bad. Diagnosis was made by road test ie. turning to the right the sound went away.
4. The top caliper bolt was seized and I used an Irwin Bolt Grip to get it out.
Good luck!
Simon
Old 26-08-2008, 08:50 PM   #20
V3RSAC3
... Fear it!
V3RSAC3's Avatar
Dude, Wheelworx is around the corner to you! :P :P just pop in and ask to speak with Richie, he will tell you!
BTW, your car is HOT, i love it
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2008, 08:37 AM   #21
XRLNT-8
XRLNT-8's Avatar
Thanks for the heads up Nathan!
Cheers,
Simon
Old 27-08-2008, 08:46 PM   #22
V3RSAC3
... Fear it!
V3RSAC3's Avatar
you know my name?
SWEEEET lol
ooh, i spotted you today driving down Henley Beach Rd. i was standing in the medium strip waiting to cross, was in my red work polo :P ... was gonna wave, but didnt wanna creep u out
Chrysler 300C Sedan
SY Territory Ghia
Old 29-12-2016, 12:42 PM   #23
Vortex-98
Vortex-98's Avatar
Default Re: Road Noise PLEASE HELP!!
Wheel bearings ?? Try jack car up an rotate the offending wheel fast an slow,check your wheel weights are still attached as they help balance the wheel and make sure all your wheel nuts are tight ,,i know it sounds dumb bt if not tight they unscrew themselves.........then if still no good get a wheel balance..i have kinda same issue with a strange whooshing noise like air induction noise or wheel needs a balance coming from p/s/f
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
