Old 26-09-2008, 09:11 PM   #1
photn
AFF Post NAZI
photn's Avatar
Default LR aftermarket Audio
Hey guys.
As i have Alpine splits in the front and Clarion 6x9 in the rear and i have the rear connected to the amp and the trigger off a cigarette lighter which only activates when the car acc is turned on.
Now i want to connect the fronts up but im not sure how to about this.
DO i connect the fronts to the amp and only have the audio activate when i turn acc on or do i find another way around it.
Cheers and let me know.
BTW im keeping stock HU cause it look OE and its decent enough.
Old 26-09-2008, 09:59 PM   #2
zetec
Zoom Zoom
zetec's Avatar
Plus it's a 6-stacker FTW, and it works off the remote.
A stock HU with amps and stock speakers still hammers.
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2008, 10:28 AM   #3
FOCUSonTHIS
FOCUSonTHIS's Avatar
Connect the front to the amp. How else you going to get any power to them
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 27-09-2008, 04:57 PM   #4
photn
AFF Post NAZI
photn's Avatar
well duh but i mean like should i worry about when turning on the stereo and having o turn the car to acc to have the audio on or just connect them up.
Old 27-09-2008, 04:59 PM   #5
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
The Factory 6 Stacker is a ripper i.m.o.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2008, 06:28 PM   #6
melbzetec
Old enough to know better
melbzetec's Avatar
Sorry to Hijack Sean......but I've been looking at these:
http://www.ryda.com.au/Boston-SX85-5...ers-p/sx85.htm
as a straight drop in upgrade. Is the standard HU strong enough to drive them? ( I am a complete nuff nuff when it comes to electricals and audio)
Sean....I think you would want the audio to only be live when you turn acc on....otherwise you'd run the risk of running down the battery (remember...I'm a nuff nuff here)
Old 28-09-2008, 09:34 AM   #7
FOCUSonTHIS
Have them come on with acc. If your worried about the amp draining the battery. Install a capacitor.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 28-09-2008, 02:54 PM   #8
RJO89
EuroFordClub
RJO89's Avatar
Capacitors are a waste of money IMO. They hold charge until they sense a drop in voltage, when they discharge to the system, then spend time recharging. They're not worth the premium you pay for them, and you really don't get that much out of them.
What sort of amp is it? 4ch? I'm still trying to understand what the question is...
Never connect an amp without a remote wire connected to something that comes on with acc, otherwise you will drain your battery, and also, there's no point, because you don't need your amp to be on unless the stereo is on. If you've already got your amp running the rears, then all you need to do is to wire the fronts up to the amp. Take the doors off, snip the speaker cables, then solder new speakers cables on, run them through the door looms, down the door sills and to the amp in the boot (or under the seat, wherever it is).
If you're hooking up another amp, just daisy chain the remote wire from one amp to the next one, rather than running an entirely new remote wire.
Far from stock... --- SOLD :
Old 28-09-2008, 06:31 PM   #9
BlackLS
yum
Don't run the amp all the time 24/7. You'll just drain the battery.
Better off to wire remote wire like the other amp. Cig lighter.
2005 LS Focus LX
250,000kms.
