12-12-2008, 08:09 PM | #1 | ||||
Does the manual 2003 Mazda RX8 put out 177Kw and weigh 1377kg? Or 170Kw? Wikipedia seems to insist on it weighing in between 1309-1377Kg. Thanks much.
12-12-2008, 08:30 PM | #2 | ||
Where to next??
12-12-2008, 08:33 PM | #3 | ||
Broken
EngineFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed
Configuration Rotary Rotary Capacity (cc) 1308 1308 Compression Ratio 10:1 10:1 Engine OutputFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Max Power (kW @ rpm) 141 @ 7000 170 @ 8200 Max Torque (Nm @ rpm) 220 @ 5000 211 @ 5500 ExteriorFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Body colour bumpers Std Std Body colour side protection mouldings Std Std Body colour door handles Std Std Body colour exterior mirrors Std Std Sun roof Std Std Alloy wheels Std Std Electric outer mirrors Std Std Integrated headlamp fog lamps Std Std TransmissionFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Type 5 Speed manual 6 Speed manual Gear Ratio 1st 3.483 3.760 Gear Ratio 2nd 2.015 2.269 Gear Ratio 3rd 1.484 1.645 Gear Ratio 4th 1.000 1.187 Gear Ratio 5th 0.762 1.000 Gear Ratio 6th - 0.843 Gear ratio Reverse 3.288 3.564 Final gear ratio 4.444 4.444 Drive wheels Rear Rear SteeringFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Type Direct drive electrical Direct drive electrical Turning circle (m) (Diameter) 10.6 10.6 SuspensionFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Front Front double, wishbone Front double, wishbone (Sports) Rear Multi-link Multi-link BrakesFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Front Ventilated discs Ventilated discs Rear Ventilated discs Ventilated discs Hydraulics ABS with EBD ABS with EBD Exterior Dimensions (mm)Feature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Length (mm) 4430 4430 Width (mm) 1770 1770 Height (mm) 1340 1340 Wheelbase (mm) 2700 2700 Front track (mm) 1500 1500 Rear track (mm) 1505 1505 Wheels and TyresFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Road Wheels 16 x 7.5JJ 18 x 8JJ Tyre Size 225/55 R16 225/45 R18 Spare Wheel Dealer option Dealer option Warranty and ServiceFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Service Plan 5 year / 100,000km 5 year / 100,000km Warranty 4 year / 120,000km 4 year / 120,000km MazdaMotion Roadside Assistance 3 years - Service intervals 10,000 km or 12 months 10,000 km or 12 months Weights and CapacitiesFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Gross Vehicle Mass (kg) 1371 (Kerb) 1384 (Kerb) Towing mass (kg) Not allowed Not allowed Fuel Tank Capacity (L) 61 61 Luggage volume (L) 290 290 Interior Comfort and ConvenienceFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Automatic air conditioning Std Std Leather covered gearknob Std Std Ignition key illumination & sound Std Std Illuminated entry system Std Std Glove box illumination Std Std Driver foot rest Std Std Remote fuel filler release Std Std Ice- In Car EntertainmentFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Radio/ 6-CD Std Std Audio control on steering wheel Std Std Speakers and tweeters Std Std SeatingFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Front seat - manual adjustment Std Std Driver lumbar support Std Std Rear map pocket Std Std Leather seat trim Std Std Safety and SecurityFeature Mazda RX-8 Std Power 5 Speed Mazda RX-8 Hi Power 6 Speed Front dual airbags - driver and front passenger Std Std Curtain airbag - front and rear Std Std Side airbags Std Std Seat belt with pre-tensioner and load limiter Std Std Seat belt warning light Std Std Transponder immobiliser Std Std Central locking Std Std Keyless entry system Std Std Site MapPrivacy & DisclaimerVisit Mazda GlobalInformation ManualInstall Adobe FlashCopyright © 2007 Mazda South Africa
The Scud GT 11.4 @ 128, 1.88 60ft. |
12-12-2008, 08:37 PM | #4 | ||||
Thanks boys, thanks much. Though, different results?
12-12-2008, 08:48 PM | #5 | |||
Where to next??
The info on drive is the same across different sellers, so the specs for that model must come from their own database??? |
12-12-2008, 09:25 PM | #6 | ||
They have different tunes depending on whether manual or auto.
6sp Manuals were tuned for 170kW @ 8200rpm / 211Nm @ 5500rpm. 4sp Autos were retuned for a bit more torque earlier and with a lower rev limiter due to torque converter limitations. Resulted in 141kW @ 7000 rpm / 220 Nm @ 5000 rpm. |
12-12-2008, 09:38 PM | #7 | |||
FORMERLY TX3DUDE
wet vs dry weight maybe?
12-12-2008, 09:54 PM | #8 | |||||
12-12-2008, 10:35 PM | #9 | ||
Tricolore Tard
Maybe you might want to try.
http://www.rx8club.com/ http://www.rx8club.com.au Might have some info there.
13-12-2008, 12:28 AM | #10 | ||
Kerb weight : Manual 1337kg or 1354kg with leather trim.
Tare mass : Manual 1299kg |
