08-01-2009, 11:07 AM | #1 | ||
Well today i pulled out one of my spark plugs as i have a detonation problem and found out they are set to over 2mm. was just wondering does anyone know the part numbers for the correct plugs. got qouted $160 for iridium plugs but couldnt find any of the cheaper plugs. dont really wanna pay 20 a plug. so any parts numbers would be usefull. thanks
08-01-2009, 11:12 AM | #2 | ||
Afterburner + skids =
NGK BPR5EFS-13. It's what I use in mine. They should only be around four dollars each.
08-01-2009, 12:48 PM | #3 | ||
just fitted those plugs and fixed my detonation problem thanks for your help
08-01-2009, 01:02 PM | #4 | ||
No worries. What did they cost if you don't mind my asking?
08-01-2009, 01:57 PM | #5 | ||
umm around 5 dollars each. alot better than 20 each lol
08-01-2009, 03:40 PM | #6 | ||
Rockin '67
Yeah I just went to get plugs for my 6cyl and they were $22 dollars each so I think I will try and find some cheaper ones.
08-01-2009, 07:28 PM | #7 | ||
Right out sideways
glad to hear your prob fixed.
i got the irridium NGK's from Bursons for $14 each this week for my XR8, they are great plugs got 140'000 out of the last lot
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
19-05-2009, 04:29 AM | #8 | ||
BLOWSVO
I'm getting Denso Iridium Power spark plugs for my EF, plugs are so after looked these days. The denso Iridium's have the finest electrode point 0.4mm and are proven the best over all :-) Chu.....
19-05-2009, 08:51 AM | #9 | |||
19-05-2009, 09:21 AM | #10 | ||
cause they arent Irridiums i would say
19-05-2009, 09:22 AM | #11 | ||||
Back to Le Frenchy
The BPR5EFS-13 is the standard replacement, I spoke to NGK to confirm this, and is the best plug for the job.
19-05-2009, 09:23 AM | #12 | ||
what sort of life expectancy you get out of them ones russ?-I replaced mine with iridiums last year but when they are due again WONT be going down that road again.
19-05-2009, 09:27 AM | #13 | ||||
Back to Le Frenchy
I use a colder heat range in mine (well I did with the old heads) and changed them every 3rd to 4th oil change, so every 15-20k. I do like to know that my engine is running as well as it possible can.
19-05-2009, 09:30 AM | #14 | ||
and at 35 bucks for the set- much better option. Cheers for that.
Would my iridiums still have life in them?- i have done around 25-30k on them.
19-05-2009, 09:32 AM | #15 | ||||
Back to Le Frenchy
19-05-2009, 09:33 AM | #16 | ||
a little off topic, but how often should leads and coil packs be changed- i did the whole lot together around 30k ago.??
19-05-2009, 09:42 AM | #17 | ||||
Back to Le Frenchy
Leads I would think at about the 50-60k mark to play it safe. I do err on the side of caution though.
19-05-2009, 01:43 PM | #18 | ||
T3 TE50 Blueprint
I took Russels advice on the plugs, and Michael at ICE Ignitions gave me the same advice when I rang him for new leads. I was also advised to go one range colder than standard and run non-resistor plugs for best results (some will disagree), so far with no probs. So with the MSD coil packs, basic NGK plugs, and new high quality ICE leads, the engine has never run so sweet.
-Craig |
19-05-2009, 10:42 PM | #19 | ||
Boost is here!!
I love to see someone try get a set of plugs out of alloy heads after 100,000kms.
Iridiums, platinums or std plugs, im definately a beliver in regular plug changes.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
20-05-2009, 12:14 AM | #20 | ||
Made the 300 :0)
[QUOTE=XH5LWEPN]I love to see someone try get a set of plugs out of alloy heads after 100,000kms.
QUOTE] My mates car might be a toyota .but after taking the plugs to the 100,000 the thread came out with the plug ,so off with the head.He learnt the lesson the hard way.
New Owner of a fiesta ST |
20-05-2009, 07:25 AM | #21 | |||
T3 TE50 Blueprint
[QUOTE=5 FTR 5]
05-07-2010, 10:41 AM | #22 | ||
I just replaced the plugs and leads on my NF fairlane v8 and were surprised to find motorcraft branded plugs and leads! could these be the originals? The car has done 165k. (PS I had no trouble getting them out... apart from breaking 2 of them cause of the angles i had to use the ratchet at )
On the same topic tho, the car now doesnt run smoothly and seems to be lacking power like one cyl isnt firing. Tho it doesnt happen every cycle, just once or twice a minute at idle and i only occasionally notice it on the highway. I've checked that all the leads are on properly and that they are clean inside the lead ends. Is it possible for a lead to be faulty and if so how can u tell. The other option is that the plugs I got were wrong, I got the EL xr8 plugs (thinking they were optimised for performance) but the gap on those were smaller at 1.1mm as opposed to 1.4mm for the standard E-series v8s. Could this be the issue?? MJ |
26-08-2010, 08:04 AM | #23 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
26-08-2010, 11:08 AM | #24 | |||
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
26-08-2010, 11:32 AM | #25 | ||||
Back to Le Frenchy
I've removed ones from a 110k car that were completely fried. Car seemed to run fine but after replacement the difference was quite noticeable.
26-08-2010, 12:24 PM | #26 | |||
Former BTIKD
26-08-2010, 01:23 PM | #27 | ||||
AU DIE HARD
26-08-2010, 02:01 PM | #28 | ||||
Back to Le Frenchy
26-08-2010, 02:05 PM | #29 | |||
26-08-2010, 02:21 PM | #30 | |||
