Old 04-03-2009, 10:06 AM   #1
wayne2208
Unhappy auto change down into First Gear for 07 Focus LT
My 2007 focus has an annoying habit of letting you know when the auto changes down to first gear. Usually when you are rolling to a stop/give way sign the car will be down to about 5km/h when it changes down causing the car to lurch slightly and makes it hard to come to a stop smoothly.
I usually slow down and let it coast without pressing on the brakes much, so when it does shift down to 1st gear, sometimes it is very obvious..
Is there anyone has the same problem?? I recon it's the problem of the gear box and will go to dealer tomorrow.......
wayne2208 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 10:08 AM   #2
RJO89
EuroFordClub
RJO89's Avatar
This is a very widely reported problem. Do a thread search on this issue and you will find a long thread about it. I think the problem was narrowed down, but I can't remember exactly what it was about the gearbox that was stuffing up.
Far from stock... --- SOLD :
Old 04-03-2009, 12:02 PM   #3
DZFord
DZFord's Avatar
Good luck getting that fixed...
Mine is a 06 LS and has the same problem. I took it back to the dealership and they kept telling me "they all do it"- which isn't true, since I've test driven other LS's.
I wasn't happy so I took it under warranty to Bayford Ford (transmission specialists). It's had the whole transmission out TWICE, with valves, springs etc replaced, and that still didn't fix the problem. Ford keep putting it down to a "timing problem" / ECU.
Ford wouldn't even enteratin the idea of having the transmission replaced.
Let me know if you have any luck.
Old 04-03-2009, 01:58 PM   #4
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
Sorry if I don't have the correct terminology to describe this, I got a 06LS auto.
If i downshift early (in tiptronic mode), it feels like the brakes activate suddenly to bring the revs down so that the engine can change gears safely without doing any harm. (engine brakes perhaps?).
Could this be what you are experiencing when you come to a stop?
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 02:16 PM   #5
DZFord
DZFord's Avatar
No, it's a definite "clunk" or "shudder" as the auto trans downshifts from 2nd - 1st at low speeds.
Old 04-03-2009, 06:50 PM   #6
TITO
I fixed this problem by getting rid of the car. Your dealer wont touch it, better off going to a tranmission shop and pay a few hundred bucks and fix it your self and save your nerves.
TITO is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 08:31 PM   #7
DZFord
DZFord's Avatar
By the way, I think I forgot to mention the Focus auto tranmission is crap?
Old 04-03-2009, 09:11 PM   #8
sumpPUMP
SUMPA's sedan
sumpPUMP's Avatar
lucky for us manual focus drivers ey?
do you guys recon there are just as many manuals as autos as the focus is for economy driving?
'07 sapphire black manual LT focus zetec sedan
6.5" alpine dvd player - alpine splits - response amp - alpine 12" sub - lovell's supalow springs - LV XR5 Focus wheels - Kumho KU31's - black leather - tint
sumpPUMP is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 09:16 PM   #9
DZFord
DZFord's Avatar
Probably. I'll never get an auto again. It SEEMED like a good idea at the time, since I do 95% of my driving in peak hour!
Old 05-03-2009, 09:46 PM   #10
wayne2208
I just got my focus back today after leaving it there for all day.
They said they have checked operation of transmission and found ok at time of check. Some words I found in my invoice "found level down 700ml, topped up carried out IDS test and found all ok".
When I drove it home, the lurch problem remained there........damn....
Maybe I have to to the transmission shop or get rid of it.........
would go for Honda or Toyota.....maybe.........terrible experience... :
Old 09-03-2009, 02:00 PM   #11
20focus05
I wanna XR5
20focus05's Avatar
my mate used to work for ford and they found the problem to be the servo that applies/releases of the band. these trans use oil pressure to release the band along with a spring, different to many other transmissions.
I see these trans very often but in the mazda.(80,000km on average) actually not seen a focus yet.
a bump to stop issue can be many things especially with the new cars where the trans and engine talk to each other.
Best to start with check band adjustment(requires special tool), and pressure tests(direct clutch, cause it also feeds band release). A good auto trans place should be able to check these out
I had a mazda one recently totally give me the sh!ts, after pulling it out and rechecking everything it still did not work exactly right, so i used the parts in a new case. came up all good. obviously a hairline crack in the case somewhere that we could not see.
Makes you want to cry sometimes.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 02:29 PM   #12
want-a-XY
want-a-XY's Avatar
My Mum just bought a 2005 LS CL auto. i find it makes this shudder only intermittently, but i'm the only one who notices it. it isn't bad enough to be a problem..... it's not that bad so i reckon it'll be alright though
want-a-XY is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 10:27 PM   #13
focus181
We have a 2008 LT experiencing same lurching problem. No luck with 2 dealers or Ford themselves. I'll be calling Office of Fair Trading next
focus181 is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 09:50 PM   #14
fishontherun
hi focus181,
can you give us an update on what OFT say? I was having same problem with my 08 LT.
fishontherun is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2009, 12:44 PM   #15
focus181
Originally Posted by fishontherun
hi focus181,
Currently in the process of lodging a written complaint with OFT
Stay tuned.....
Old 18-05-2009, 03:12 PM   #16
focus181
Complaint was lodged last week - no word yet. We might stand a better chance if a few more people lodge complaints with OFT - it can't hurt, and at least OFT (and Ford) will know it's potentially a more widespread problem
Old 18-05-2009, 08:04 PM   #17
mohit
mohit's Avatar
I will lodge a complaint. What do i need to do? You can PM me if you want.
mohit is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2009, 09:21 PM   #18
focus181
Depends what State you're in -
Qld - Office of Fair Trading - http://www.fairtrading.qld.gov.au/
Vic - Consumer Affairs Victoria - http://www.consumer.vic.gov.au/
NSW - Office of Fair Trading - http://www.fairtrading.nsw.gov.au/default.html
Not sure about the other States.....
You can either ring them or just go online and follow the links on any of the State websites to Lodge a Complaint.
The sites should tell you what you'll need to include with the Complaint form - ie copies of all correspondence you've had with your dealer and Ford, copies of any service reports, etc, etc
Good luck
Old 19-05-2009, 12:02 PM   #19
fishontherun
I'll lodge a complaint too.. in vaguely hope that they will make Ford to do a recall .. :-)
