Old 18-03-2009, 08:31 PM   #1
Mick K.
Mick K.'s Avatar
Unhappy Strange smells
Hi,
My LR Focus Zetec is smelling really bad after a bit of driving. It smells like a typical clutch or brake smell, but gear changes are fine, clutch isn't slipping and the brakes seem to be OK. I had rear pads done about 20K ago and front rotors and pads about 40K ago.
Any suggestions on how I can isolate the cause? Any other suggestions on what may be causing an asbestos like burning smell?
Thanks,
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2009, 10:36 PM   #2
Buzz Box
Wheel Wally
Buzz Box's Avatar
Oil drips onto exhaust??
Currently:
2006 Ford Fairmont Ghia BF
1999 Land Rover Discovery Series II - "Thomas The Tank"
Previously:
2009 Ford Focus - "The Bubble Car"
2002 Ford Futura Wagon - "The Big White Wagon"
1996 Ford Falcon - "Ophelia"
1975 Jaguar XJ6 - "The Beast"
Buzz Box is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 10:59 PM   #3
Mick K.
Mick K.'s Avatar
Looks like that might be the case. The air con isn't working as well as it usually does and the battery was flat the other day so I'd say it is an oil leak that is hitting the exhaust as well as getting on the belt that drives alternator and a/c compressor.
Any idea what gasket / join / seal this might be from?
Looks like I'll give the local Ford dealer another chance to show me how much they know about Focii. :(
MK
Old 17-04-2009, 12:33 AM   #4
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
If you suspect this oil leak, while the car is running with the aircon on, look down at the exhaust system through the engine bay and see if there's any smoke from it. That way you can eliminate that as the cause.
Old 21-04-2009, 09:49 PM   #5
Mullett
Badly Focused
Mullett's Avatar
Belt slippage?
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 09:05 AM   #6
Mick K.
Mick K.'s Avatar
Was a stretched accessory drive belt with fragments of the old belt ingested into the alternator. $175 later (new belt + 0.4 hrs labour) my battery is charging again, the air con is working and the burning smell seems to be lessening.
Thanks for the suggestions!
MK
Old 17-05-2009, 09:47 AM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
Funny how nobody picked that one! : LOL
