Old 26-05-2009, 04:18 PM   #1
brad`
The Monty
brad`'s Avatar
Default Proteck brakes and pads any good ?
i currently need new front brakes more so pads as the passangers side is around 1.5 - 2mm think (really bad i know)
i was woundering if anyone has used or delt with Proteck's range ?
i got quoted - $55 for a pair of pads
- $65 for each disc
i forgot to ask how much for slotted.. even tho i like the look better
is that reasonable or ? i never had to deal with brakes so not to sure on the price and stuff
let me know what u think
brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2009, 06:55 PM   #2
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
never heard of proteck.......but I'm sure somebody has.....
Old 26-05-2009, 08:00 PM   #3
mickyyyy
u sure its not protex????
Protex has released a new range of slotted and slotted and drilled rotors which are heat treated so there stronger and less prone to cracking. DBA 4000 or 5000 rotors are heat treated and apparently the metal used in the protex rotors are just as good or better than DBA.
There centre hubs are also painted but not sure what sore of ventilating the rotor has as DBA have the kangaroo design system which works well.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2009, 08:43 PM   #4
XR Lita
XR Lita's Avatar
The protex rotors are very good and have an awesome build quality. We use them from time to time here at work, and have never had any dramas with them.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2009, 09:53 AM   #5
brad`
The Monty
brad`'s Avatar
oh ok maybe it is protex, couldnt understand ladie on the phone very well,
what about there pads tho anyone used or had anything to do with them ?
Old 27-05-2009, 12:53 PM   #6
XR Lita
XR Lita's Avatar
Same as the rotors. Good pad, not the best in terms of bite, but very good general purpose pad, with good life. Not known to squeal either, which is good.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
