Old 20-07-2009, 12:29 PM   #1
webby_191189
low wagooon
Default Anyone replace a power window reg before?
As the thread states has anyone here removed one before? Mine died on sat and i am unable to put my window up. I ordered a new one this morning and just wondering how you remove it all.
Thanks AJ
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 07:20 PM   #2
Damozxr6
FORD4LIFE
Damozxr6's Avatar
id be interested to know how this is done too. mine are getting slower everyday.
:evil3: AUII XR8 UTE. BLACK. MANUAL :
: out: HSV " I DONT WANT ONE" :monkes:
Damozxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 07:24 PM   #3
Black XR
Narooma blue XR8 ute
Black XR's Avatar
mine sticks about 2/3's of the way up will a new reg fix it ?
Black XR is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 07:25 PM   #4
JOSH
JOSH's Avatar
you need to lube your channels, the rubber goes dry and the glass sticks to it
03 BA Pursuit
Blue Power Racing Developments
(03) 93053000
Ray Prescott Auto
(02) 49902488
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 07:46 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
99 times out of 100, it's nothing to do with the reg, get some silicone spray on the channels and dig out your switches and douse em in carby cleaner, and give me some rep points cos i just saved you a whole lot of effort and expense.
Old 20-07-2009, 09:12 PM   #6
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
If cleaning doesn't help they do wear out, they are an electric motor driving a wire around plastic pulleys, the wire can break, the pulleys wear out, the wire cuts the pulley in half, the spot weld breaks and the whole things bends, the electric motor can burn out there are many reasons
Basically take door trim off
Remove window from 2 plastic bits clipping it to glass
Use a screwdriver at each end and lever white tabs out while lifting glass up
Window needs to be 3/4 down to get acces for this
Push window UP to top so glass is out the way, maybe tape up as they sometimes fall down and chop your hands
A couple of nuts to undo motor
A couple at top of the centre rail and a couple at the bottom
Unplug the motor
Remove the thing, a bit fiddly but it will come out
Reverse to put back together
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 10:20 PM   #7
NC1183
NC1183's Avatar
If its a front window, i'd pull the glass, really easy to do, never done a back window ute's don't have them, and really lube up the channels before you put it back together.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 10:32 PM   #8
Black XR
Black XR's Avatar
Mine doesn't just stick it drops at the front & I have to lift it then it will go the rest of the way up on it's own
Old 21-07-2009, 12:19 PM   #9
webby_191189
low wagooon
well i got the 1, window channels were lubed, different switch was tried. Motor has burnt out. Thanks for the info. A new reg from bursons was $90
Webby
S2 AU XR6 UTE
Old 22-07-2009, 09:28 PM   #10
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
bugger
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2009, 10:32 PM   #11
webby_191189
low wagooon
Originally Posted by Sorted
bugger
post whore?
New window reg turned up today, fitted it quite easily cleaned the switchs while i was going so all is well. Bit of an effort after working 13 hours but got it done after a bit
Webby
S2 AU XR6 UTE
Old 23-07-2009, 09:10 AM   #12
Sorted
Sorted's Avatar
Did you take pics to help other members or did you just use them for info again
Tuned by DYNOMOTIVE
Old 23-07-2009, 10:04 AM   #13
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Mines not AU but has anyone tried a aftermarket one? Im not sure it could be any worse than the original Ford part....
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2009, 12:16 PM   #14
Sorted
Sorted's Avatar
I have an aftermarket one fitted into my drivers door on my EF - no problems
Apparently there are a few different versions of the aftermarket ones and one of them is a real dodgy one that will fail again :( obviously its the cheapest $$ one - unsure the brand name
Tuned by DYNOMOTIVE
