Old 26-10-2009, 09:50 PM   #1
TheInterceptor
Cruising...
TheInterceptor's Avatar
Lightbulb Lights behind grill au2
Gday,
Might be a stupid idea, but i reckon a set of foggies behind the grill would look pretty sweet.
Has anybody done this or know even if its possible?
Ive had a look and it seems a couple of bolts through the grill pins (pin thingo's holding the grill onto the car) should work, as in using the pin holes to secure the light solidly to the car...if that makes sense.
Also restricting airflow and heat damage comes to mind.
Thanks
-Mike
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:12 PM   #2
Beer Baron
Probably wouldn't let that much light through as the fins are pretty thick. Change to mesh and it would work i guess and still look half decent if done right.
What about down in the lower gap with rectangle lights ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:23 PM   #3
TheInterceptor
Cruising...
Well ive got a fairmont grill on so its the honeycomb mesh.
Id have put some in the lower gap but i was after something that looks alot better than the stockish positions.
Old 26-10-2009, 10:34 PM   #4
smally289
growing up is optional
smally289's Avatar
It's possible I reckon, but not really practical IMO.
The effectiveness of the lights would be diminished and then you also have the reduced airflow to the radiator and condensor which may or may not cause a problem.
Fog lights need to be down as low as possible to work properly anyway.
Personally I think it would be like putting a set of 12 slotters on it and jacking the rear up with air shocks - very 70's.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:41 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
It would be silly, but super super super cool.
Old 26-10-2009, 10:48 PM   #6
TheInterceptor
Cruising...
I agree, but i was thinkin for it to be more for looks than practicallity which was the original idea.
With the airflow maybe removing the grill and puttin a pair in the gap but most likely look bad instead of what im after!
70's
I still reckon just that woudl make it look that bit unique.
cheers
Old 27-10-2009, 12:29 PM   #7
V3RSAC3
... Fear it!
V3RSAC3's Avatar
It would work ... I had these; and they shone up the night beautifuly
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 12:37 PM   #8
FORD5
FORD5's Avatar
Haha awesome, they still on the car mate?
FORD5 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 12:42 PM   #9
Mr Hardware
i'd get a crapola s2/3 forte grille from the wreckers and cut holes in it
that'd be super cool
Old 27-10-2009, 12:52 PM   #10
V3RSAC3
... Fear it!
V3RSAC3's Avatar
Yeah wired up to a switch inside the car.
Also used to have these but got rid of them;
Chrysler 300C Sedan
SY Territory Ghia
Old 27-10-2009, 01:14 PM   #11
BIGJB
BIGJB's Avatar
Oh the cops must have just loved your car V3RSAC3. lol
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 01:19 PM   #12
JC
JC's Avatar
You mean like this?
That grille was meshed, so let plenty of light through through. Had the same setup once I fitted an XR bar too and worked well enough, so the slats don't really block that much. In this position, they have to be high beams though, unless you point them right to the ground, but then they wouldn't be much use.
I mounted them on the radiator support panel (upside down), and turned the lens around so top was still the top.
Ford Performance Club ACT
Old 27-10-2009, 01:21 PM   #13
V3RSAC3
... Fear it!
V3RSAC3's Avatar
And what did you wire them to JC? To the highbeam's or a seperate switch?
Chrysler 300C Sedan
SY Territory Ghia
Old 27-10-2009, 01:28 PM   #14
JC
JC's Avatar
If the lights are equal to or above the main lights of the car, then they have to be wired as high beams. Fog/driving lights can only be mounted lower than the main beams. Oh, and legally, you have to wire both to correct circuit and a switch.
Circuit goes like this:
High beam wire to switch (or parking circuit to switch for foggies/driving/daytime running lights)
Switch to pin 86 on relay
Lights to pin 87 on relay
Earth to pin 85 on relay
Battery to pin 30 on relay
Old 27-10-2009, 01:33 PM   #15
JC
JC's Avatar
Then there was this:
Spotties mounted to number plate bracket, and foggies in the gap at the bottom of the bar:
Spotties on an XR are really only for looks/effect though, as the main high beam is excellent. The foggies are necessary for 3 months every year in Canberra (foggy mornings)
Old 27-10-2009, 02:52 PM   #16
Mr Hardware
^The Eight Eyed Spider!
Old 27-10-2009, 04:35 PM   #17
BIGJB
BIGJB's Avatar
Originally Posted by JC
You mean like this?
That looks great JC, it's nice and neat.
Old 27-10-2009, 06:03 PM   #18
TheInterceptor
Cruising...
Thats real nice v3rsac3, almost made me change my mind hehe
Know where i can get me some red parkers? i know they arent legal but the main beam would drown out the red right?
Woulden't want to be pulled for it.
JC your spot on the idea with the black XR, exactly what im looking to do.
Looks awesome as
How is it bolted on and where?
Old 27-10-2009, 06:31 PM   #19
deanus90
autobarn they keep heapsa colour parkers. blue green red yellow white
deanus90 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 07:20 PM   #20
GS608
Looks awesome as
i've had blue parkers for ages and havn't been pulled up for em, the main lights do drown them out but if you see the lights at a certain angle then obviously the blue parkers stand out like dog balls.
how'd you go about gettin the flashing lights in the grill? just some led's and a flasher circuit?
Old 27-10-2009, 07:33 PM   #21
JC
JC's Avatar
Looks awesome as
Do you mean the front bar, lights etc? if so, check out Ronwest's how to of sorts:
http://www.fordforums.com.au/showthread.php?t=11246213
Old 27-10-2009, 07:55 PM   #22
Mr Hardware
ahahahaha V3RSAC3, that's awesome!!!
Old 27-10-2009, 08:22 PM   #23
TheInterceptor
Cruising...
I meant the light positions behind the grill.
The grill is also a great idea but if need be ill change it like yours.
Also, will having the lights on for a long period of time somehow kill the battery?
..thats what ive heard anyway.
Sorry for all the questions fellas
Old 27-10-2009, 08:47 PM   #24
Mechan1k
Mechan1k's Avatar
Or you could go with something like this:
Old 27-10-2009, 08:55 PM   #25
V3RSAC3
... Fear it!
V3RSAC3's Avatar
I'm going to connect up all my LED's at once (maybe tomorrow) and film with all my lights going off! Goes off like a XMAS tree lol. ...
Umm the ones that flash in the grill are LED's with a Intercanged box on them! I'll take some pics tomorrow for you. Got the whole system from Motoquipe. ... As for being able to see them, The main lights DO drone them out HOWEVER you can see them up close, but because they were parker replacment LED globes you can't turn them off when your beems are on. Although the police didn't say anything about them in RBT's but i DID however get in trouble for having the ones in the washed jets, APPARENTLY any lights above the headlights are illegal but he just told me to disconnect them so no big fuss really nice guy.
Chrysler 300C Sedan
SY Territory Ghia
Old 27-10-2009, 08:57 PM   #26
Ride
Stay Classy ™
Ride's Avatar
You mean like this?
JC I'd love to know what that mesh is that's surrounding the Ford badge, would look the goods on the front of the Ghia :
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 09:10 PM   #27
TheInterceptor
Cruising...
Mechan1k, thats one sick lookin ute!
I was planning to do something like that, although right now the cost of it all is a bit much for me :voldar02:
Sounds like fun V3rsac3 :
Old 27-10-2009, 09:25 PM   #28
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
this is what i have done its wired up to a Toggle switch on the Fuse box Lid
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 09:36 PM   #29
TheInterceptor
Cruising...
Thats tops!
is that a simple LED setup or..? if its that simple, i might go for this than the lights mmmm
Old 27-10-2009, 09:52 PM   #30
V3RSAC3
... Fear it!
V3RSAC3's Avatar
Beleive it or not that type of set up isn't as difficult as you think.
POELWYK would probably be using a Neon Strip light or LED which had been mounted in the grill. 1 Wire connects to the battery, the other goes through the whole in your firewall (just a rubber plug in the engine bay) which come out where the clutch would under your carpet. This is where you wire that wire to a switch and then the connect another wire to the switch and run it too a negative point in the car. And there you can turn them on and off from inside the car ;) ... It's a good effect for not a big effort. That was my original goal along side with the spotty's in the grill.
Chrysler 300C Sedan
SY Territory Ghia
