31-10-2009, 04:48 PM | #1 | ||
Today when I raised the front left window it ripped out the rubber from the moulding on top of the door at the bottom of the window "if you know what I mean." How do I remove the old moulding and install a new one. Are they clipped or adhered to the door? BTW its an AU1 wagon. Cheers Russell.
01-11-2009, 01:20 PM | #2 | ||
Lost Boost Gained Class
hey mate i just did mine on my S 1 Sadan if u look at the end of the moldings theres a screw undo it with a phillips head screw driver then pull it up and off (the modldings) thay will opo off thay are only held on with 4 - 5 clips and that 1 screw then get a can of Liqud Sylican and spray it down the tracks and loob them up then wide the windows up and down a heap after u done this thay will be like a new window on a new car
I hope this helps Cheers Andrew.
2006 BF Fairmont Ghia
2001 AU Falcon |
