Old 05-12-2009, 10:01 PM   #1
richo77
richo77's Avatar
Thumbs up Water pump dripping coolant
Hey guys, need some advice please.
My water pump on my XR8 is dripping coolant slowly from the bottom end of it. Does this mean it needs to be replaced or can it simply be fixed with gasket silicone around the edges of it?
Nathan
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2009, 10:31 PM   #2
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Usually when a water pump starts to drip it mean's it's cactus, they are mean't to drip when stuffed it's a tell tale sign, are you sure this is where it's comming from.
Old 05-12-2009, 10:36 PM   #3
saber
Yeah, the water pump has just about had it. Time to replace
saber is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2009, 10:48 PM   #4
richo77
richo77's Avatar
thanks - should be a relatively straight forward job hey? Theres plenty of room to work in there without having to take out the radiator.
Old 06-12-2009, 09:58 AM   #5
CPOCSM
Replace it - not a difficult job but also check the timing case while you are there. Nearly all water pumps have a little hole under the spindle shaft and when that starts to seep it is time to change the pump out. This is telling you the seal is on the way out and in turn the bearing is not long for this mortal plane.
When you pull the pump make sure to note where the bolts go...
Have fun!!
CPOCSM is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2009, 11:22 PM   #6
FC:LTD
Quite a simple job apart from figuring out where the bolts go when asembling as previosly stated !
FC:LTD is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2009, 12:27 AM   #7
FTe_XR8
formerly "3x-puursui7"
yeh easy job, as mention have a good look at your timing cover. Best way to remember where the bolts go is just put them in the holes in your new pump as you pull them out one by one, also pays to change the bottom hose and the little "L" shaped one while your in there.
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2009, 10:09 PM   #8
richo77
richo77's Avatar
Well i pulled off the old pump tonight straight forward enough, couldnt wriggle off the botton hose so ended up cutting it off. Probably best to replace it anyway. Will tackle putting the new one back on Friday.
cheers for the help, made the job all the more easy
Nathan
Old 09-12-2009, 11:04 PM   #9
IH8HSV
XR6T 400kw(well one day!)
IH8HSV's Avatar
Nathan
Doesn't hurt to put Permatex gasket seal on the water pump gasket either. ( Its looks like Vegemite and works very well ). Also good to put on the inside of the hoses you are going to replace.
Creates a good permanent seal.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory
IH8HSV is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2009, 02:47 AM   #10
kratas
Goes like an AU
kratas's Avatar
I also recomend checking the timing chain cover. Put the car in to fix an oil drip. Turns out water pump was gonners and the timing chain cover was loose causing the oil leak. ;)
1998 Series 1 AU fairmont GHIA:King Springs lowered - Tickford VCT six - Recod transmission - full TS50 body kit - 17'' BA rims - 25% tint - full leather - Exhaust system Soon to be: Extracted (pacey comps) - Flash Tuned - Dyno
kratas is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2009, 08:04 AM   #11
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Yeah, a little too permanent for me. : That stuff is from the dark ages.
Loctcite Master Gasket (515?) is much friendlier stuff. As in, easier to clean off.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2009, 09:23 AM   #12
Hords
Treasure your balls?
Hords's Avatar
When I replaced my water pump it ended up being the o-ring around the heater tube that had hardened and caused the drip. May as well replace that to while you're at it.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 07:16 PM   #13
GK
Walking with God
GK's Avatar
I'm wth Hords.
Both my AUs have had this O-ring replaced, and it's been the cause of similarly described coolant leaks.
The wagon did have the water pump replaced by the previous owner under warranty though.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 15-12-2009, 11:47 AM   #14
HypnoTECH03
First Ford Owner
HypnoTECH03's Avatar
as you said "It looks like Vegemite" obviously using Permatex Ultra Black,
for Water Pump usage the best Permatex Gastek Maker is "High-Temp RED"
as its specific for Water and Higher Temperatures then Ultra Black
but it shouldnt hurt using Ultra Black maybe on the I6, but the V8 would highly recommend Hi-Temp RED
If you dont like the heat, then get out of the bloody fire
HypnoTECH03 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2009, 03:57 PM   #15
saber
I used Permatax Ultra Blue when doing the water pump in the XF, worked like a charm.
Old 17-12-2009, 01:11 AM   #16
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
I thought those silicone-like rubbery sealants (permatex blue, black red) where for areas like the rocker cover, where its got a rubber gasket, and you don't tighten the joint up very tight. You tighten it up loosely, let the blue/red/black dry overnight, then torque it up, but not very tight. On a water pump with paper gasket, you tighten it up pritty tight, and the silicone would just squeeze out. I think the permatex non-hardening no.3 is ideal for paper gaskets like on the water pump. Or is that the vegemite stuff you talking about?
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2009, 11:24 AM   #17
HypnoTECH03
First Ford Owner
Default RTV Silicone Permatex
Nah the recommended Gasket maker for the water pump is High-Temp red.
i work at Supercheap Auto Head Office, along side the Category managers creating the Catalogues!.. and just over the last 2 weeks its been Permatex advertised everywhere, and the High-Temp Red happen to be one of the Main products
And when it comes to tightening with Gasket maker, you apply the Silicone on both ie, water pump surface, then put gasket on & apply Silicone to the gasket then bolt back onto the engine. only tighten till finger tight, allow the silicone to dry for 1 hour then tighten to recommended Torque level, and the Silicone will take around 24 hours to Fully Cure..
Old 17-12-2009, 06:02 PM   #18
AMB
........i work at Supercheap Auto Head Office, along side the Category managers creating the Catalogues!.. ....
Thanks HypnoTECH03, the silicone is good for filling a big gap, but i wouldn't like to use a silicone type 'gasket maker" on something with a paper gasket that is tightened up really tight, even if they do recommend it.
Off topic, HypnoTECH03, maybe you can do something about supercheap selling sikaflex-227 (fast curing automotive sealant) as an adhesive. Sikaflex has proper strong adhesives in their range but supercheap don't stock it. If you ask for Sikaflex adhesive, supercheap will try to sell you sikaflex-227 sealant, and the receipt actually says sikaflex adhesive.
Old 17-12-2009, 09:06 PM   #19
Hords
Hords's Avatar
ke ???
Old 18-12-2009, 02:59 AM   #20
IH8HSV
IH8HSV's Avatar
LOFTY...... Yes it is from the dark ages - But it sure does seal!
But thats what you want. Its very rare you have to change a water pump or hoses again in the life time of your car. So why not seal it for good!!!
Be like Ford: And not care about the next man.
