Old 08-02-2010, 12:54 PM   #1
secur_ed
Default replacing central high brake light bulb on 2005 Fiesta
Hi
Has anyone tried to do this? The manual says to remove grommits, use a flat head screwdriver to undo springs to remove the central high brake light but the for the life of me I can't see in the tiny whole to find out what to do. I've tried waving the screwdriver about in there but with no joy.
Any tips?
Thanks
secur_ed is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 07:34 PM   #2
dannyhilton
dannyhilton's Avatar
I had to dow my left hand one on the old WP. Was a bit tricky doing it first time around as I was cautious not to break anything. You'll need a one of those special star face screw drivers. Inside you'll need a philips head IIRC. Undo the plastic surround that holds up the rear boot concealer thing (whatever you call this, it hides the contents of the boot). There is about three screws from memory. Undo this, and you'll have clean view to unclip the tail light. I hope his helps, I'm pretty sure this is how I did it?
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum
PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec
dannyhilton is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2010, 02:42 PM   #3
secur_ed
Thanks Danny. I've changed the side ones a couple of times now. Although tricky it is do-able. It is the central high break light I need to change now - it seems impossible but if someone has done it before????
