Old 11-02-2010, 12:57 AM   #1
Pepi69
PEPI69
Pepi69's Avatar
Default AU2 thermo fans not functioning
Hi,
Cooling fans have stopped working - checked fuse not problem - fans works off battery - and I'm not that bright, would appreciate some advice.
Thanks
aims to please.................
Pepi69 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 01:02 AM   #2
disco frank
have u checked the relay ?
there are 2 iirc in the fuse holder if u turn the fuse holder cap upside down u should see a diagram telling you what relay's and fuses are what
bit hard to explain how to check relay's best bet is go get 2 new ones should be about $20
wtf am i doing here! : : :
disco frank is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 07:31 AM   #3
aufairmontghia
XR6
aufairmontghia's Avatar
As Disco frank has said, if the two 40amp fuses are ok...
Check the relays??? There are three of these!!!
Two 4 blade 40amp relays white in colour & one 5 blade 40amp green relay.
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 11:32 AM   #4
Pepi69
PEPI69
Pepi69's Avatar
Thankyou for your prompt response gentle men - actually that would have been my next question 'which relay N#?'......
in the immortal words of Meatloaf...."2 out of 3 aint bad"...... :togo:
thanks
Old 12-02-2010, 12:10 AM   #5
disco frank
hmm i thought they went from 3 relays in e series down to 2 in the AU
being a long time since i looked LOL
Old 12-02-2010, 09:09 AM   #6
naughts
Hmmmmm Mulberry....
naughts's Avatar
Make sure they are plugged in!!!!!
Might sound silly, but they come loose.
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 09:38 AM   #7
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Might be a long shot - isn't there some sort of temperature sensor that kicks them in when the engine gets to a predetermined heat? Any chance it could be that sensor if its not the relays or fuses?
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 03:31 PM   #8
illusivedreams
Sensors to computer, computer controls fans. Hi and low function fans run in series.
My high was working low wasnt and engine was over heating.
Replaced fans $100 from wrecker. all ok now.
Au Falcon Ute S2 2001
Lowered on Kings with Bilistien Shocks all round
2.5inch cat back
K&N Panel Filter
FG XR6 17" Rims 245/45-17 tyres
XR6T Snorkle
BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads
Tow bar
Transmission Cooler
illusivedreams is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2010, 01:14 PM   #9
Pepi69
PEPI69
Pepi69's Avatar
Hi all,
took car to auto spark and he is stumped.......can't resolve problem - still not working.
I was thinking, can I just hardwire the thermo fans to the battery and let them run when ever the car is operating, even rig a toggle switch back to the cabin. I don't see why this would be a problem. My main question is do these thermo fans for au2 run at different speeds or on/off. I think the hardwire option is the best way - cost enuff already......:(
Old 14-02-2010, 11:35 PM   #10
illusivedreams
[QUOTE=illusivedreams]Hi and low function fans run in series.
QUOTE]
Quoting myself.
They are a 2 speed high and low : Again run in series. Fom what I can understand you can loose low speed and high still works.
So check that you have both/// Im not sure how its wired. Alternatively come to the wreckers and give the $20 and borrow the fans for 5 minutes there are only to bolts holding the fans in place and bottom slotts in.
See what happens you might be lucky./
2.5inch cat back
K&N Panel Filter
XR6T Snorkle
Tow bar
Transmission Cooler
Old 15-02-2010, 07:19 AM   #11
aufairmontghia
XR6
R u blowing fuses for the fans... check fuses again!!!
Then....
Check with a multimeter or aligator clips with a globe at the plug before the thermos. That way you can check for current when the low speed thermos r suppose to kicks in... just above operating temperature, between n/o on temperature gauge.
When the a/c is turned on, the thermos should come on straight away.
Old 15-02-2010, 11:47 AM   #12
SLO AU XR8
Check the 10A fuse in the dash, fuse 7 on the top row from the left
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
