13-02-2010, 06:41 PM | #1 | ||
Hey au gurus maybe some of you on here can help me out.
I have an au sr1 xr8 ute with 147,000kms on it but the engine has a rough idle i have replaced the leads & plugs i cleaned the maf sensor i also gave the throttle body a good clean but the car still runs like crap at idle but is smooth as silk throught the rev range it has me beat and don't know what it could be Also can i get a few suggestions on upgrading the utes stereo its woefull at the moment. |
14-02-2010, 07:36 AM | #2 | ||
have you checked the ISC? if not give it a clean and make sure it is working. i had a rough idle problem that turned out to be the wire to the ISC was broken. so check it has power, the wire can be broken in the loom where you cant see it.
2018 Mustang GT |
14-02-2010, 09:21 AM | #3 | |||
Back to Le Frenchy
If the above doesn't sort it then look at the HEGO sensors in the exhaust and the coil packs, they're only good for 80-90k.
14-02-2010, 11:22 AM | #4 | |||
14-02-2010, 11:23 AM | #5 | |||
14-02-2010, 03:10 PM | #6 | |||
2018 Mustang GT |
14-02-2010, 03:16 PM | #7 | ||
The Destroyer
clean/replace you're fuel filter.
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
14-02-2010, 04:27 PM | #8 | |||
