Old 28-09-2010, 11:28 PM   #1
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Default speedo and diff Gears
hey guys i have a 99 Mont with 3.9's in it and i would just liketo know if theres any way to fix the speedo so it showing the right k's
i have seen this jaycar kit u make witch fixes it but i donno about it
so much help would be good
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2010, 11:51 PM   #2
robbyj
Rob
robbyj's Avatar
There was a place, forget the name or where it was posted, that can correct the speedo, k's everything.
Im sure someone will know of it, and i presume there will be a couple of joints around.
As for a quick fix.. not sure.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2010, 02:44 PM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
Umm, try typing 'Speedo repairs' in Google and it will probably spit out at least 5 in Melb that can re-calibrate it for you.
Old 11-10-2010, 10:10 AM   #4
sly
Sly like a G6
sly's Avatar
shiftkits.com.au also sell a speedo adjuster
Sleeper, anyone?
Old 11-10-2010, 01:32 PM   #5
T3man
T3man's Avatar
I have the shiftkits speedo corrector. It's the Jaycar one already kitted and ready to wire in. Worked a treat for a few months then simply died - reminds me to email them to get another.
Old 11-10-2010, 02:34 PM   #6
POELWYK
POELWYK's Avatar
do it dose work without a problem how dose it work???
2001 AU Falcon
Old 11-10-2010, 05:09 PM   #7
T3man
T3man's Avatar
Well it is supposed to work without a problem. Just my luck I got one that fooked up. A lot of others have used them with no issues. It works by modifying the speedo signal from the transmission - you wire it in at the back of the instrument cluster. It's not too difficult. Once wired in you can adjust it until you get your speedo reading accurately. Using a Sat Nav for a reference is the easiest method these days.
Old 11-10-2010, 06:29 PM   #8
ronwest
All Bran = Regular Member
I assembled the Jaycar kit about 12 months ago. It's still sitting on the pegboard in the shed, lol. One day....
The soldering is a bit fiddly but it's not a difficult task to put it together.
Old 15-10-2010, 05:07 PM   #9
SIKSIX
Its gone V
SIKSIX's Avatar
+1 for the Jaycar unit, been in my car for three years plus, no dramas. as said before can be tuned to the exact km/h.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2010, 06:42 PM   #10
edroders
edroders's Avatar
chiptorque also adjust it using their dyno... Speedo Check
We offer a comprehensive speedo check on our chassis dyno to assess and report on the accuracy of your speedo at varying speeds. Some aftermarket modifications, such as wheels, tyres or diff ratio change can affect the indicated speed on the vehicle's speedometer in relation to the actual road speed. This service includes a written report stating the indicated and actual speed, signed by our Technical Director.
Want to correct your speedo so that it reads accurately? Check out our Speedo Corrector or contact our sales team to discuss a speedo recalibration. http://www.chiptorque.com.au/products.html#sc
"Insert witty signature here"
edroders is offline   Reply With Quote Multi-Quote with this Post
