Old 09-10-2010, 09:38 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Interior removal guide
Could someone please point me in the direction of some notes on how to remove the entire interior from an AU (ute specifically but sedan notes will do).
Just want to have some reference points handy before I attempt it.
Thanks
2024 F150 XLT
Old 09-10-2010, 09:40 PM   #2
philstoj
philstoj's Avatar
Hey aust, just have a looksee at the workshop manuals on the site, everything there
Old 09-10-2010, 10:23 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Shoot Ben (Super roo) a pm he had his all out and put a Fairmont dash and trim into his he will be able to give you some clues or see his build thread .about page 5 or 6
http://www.fordforums.com.au/showthr...3&page=1&pp=30
Originally Posted by Riksta
Old 09-10-2010, 11:40 PM   #4
b2tf
b2tf's Avatar
Probably should clarify that its only really the seats I am wondering about - the rest I know how to do. Just worried about unplugging the wiring etc.
2024 F150 XLT
Old 10-10-2010, 10:54 AM   #5
wesomc
wesomc's Avatar
Disconnect battery, remove mounting bolts, lie seat back to access pretensioner wiring plug (under seat), unplug connector and remove seat. Did mine yesterday so I can finally put all my sound gear in
Hope this helps
Wes
White MY04 Subaru Impreza WRX Hatch - Stock, airbox resonator mod, lowered on king springs
Marine Blue EBII XR8 - GT40p's, Paceys, 3in mandrel bent exhaust, Explorer Manifold, YT 1.72 RR's, 65mm TB, 75mm MAF, Thermo's...now manual
1967 Ford Futura coupe 289 C4 stock cruiser
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2010, 02:30 PM   #6
b2tf
b2tf's Avatar
Hope this helps
Wes
Certainly does - thankyou. Any warning lights on your dash when you plugged it back in or does disconnecting the battery take care of that?
I also have to remove the rails too - installing new carpet so everything has to come out but Im sure Ill be able to manage them.
2024 F150 XLT
Old 10-10-2010, 04:01 PM   #7
T3man
T3man's Avatar
The seats come out complete on the rails.
I dunno why you're stressing ... honestly, removing the seats is one of the easiest jobs. No tricks involved except for the socket head retainers for the rails/floor.
Old 10-10-2010, 06:46 PM   #8
wesomc
wesomc's Avatar
No codes will be created if battery is disconnected while they are unplugged. Just don't reconnect the battery then plug them in, is a part of the airbag system so better safe than sorry.
Wes
Old 10-10-2010, 10:57 PM   #9
b2tf
b2tf's Avatar
I dont see where I said I was stressing anywhere but there's nothing wrong with asking questions before doing something.
2024 F150 XLT
Old 10-10-2010, 11:41 PM   #10
Ptbl
Ptbl's Avatar
dont worry about the wireing unplug and away u go.. worry bout the probems later.. youll need a torx screw thing if its the same as the ea-ef/el fords ..
fordforums.com.au/showthread.php?t=11329125
The XR Build That I Shouldn't Of Sold
DAMN!
Current Daily: 2019 Ford Ranger Raptor
weekeder: 91 soarer
project: 2005 Bmw e46 coupe 1jz
bf mk2 xr6 ute magnet
Ptbl is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2010, 11:58 PM   #11
Bobman
Regulator
Bobman's Avatar
Just be careful not to scratch the paint on the sill area or plastics as you take the front seats out.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 02:34 AM   #12
blownv8au
Pro Street Au Ute
blownv8au's Avatar
You don't need torx bits, allen keys will undo them just as good. the only ones where a torx bit is really needed is the one with the post in the middle ie. Airbag.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 01:13 PM   #13
GasoLane
Former BTIKD
GasoLane's Avatar
I think the last time b2tf was stressed was the last Wagga All Ford Day.
(When's the next one Aust ?)
Old 11-10-2010, 01:30 PM   #14
T3man
T3man's Avatar
Sorry, ... I mistook your worry for stress. I realy should have said "stop worrying" I s'pose.
Old 11-10-2010, 01:38 PM   #15
b2tf
b2tf's Avatar
Oh Gawd.......
All good T3man.
2024 F150 XLT
Old 12-10-2010, 01:42 PM   #16
superroo
You can't stop the signal
superroo's Avatar
If you’re doing the carpet Austin, the list of things that have to come out are:
Seats
Center consol
Scuff plates
Bottom b pillar trim (which requires top B pillar trim and rear side window trims off)
On top of this you will need to undo the bottom dash mounts on the front of the trans tunnel.
To get the carpet out around these is a fun job. You actually need to bend these tubes out slightly and then slowly wiggle the carpet out.
Also, to get the vinyl floor out from around the shifter (that large plastic support) I had to slit it from there to the airbag module. I can't remember doing this to the carpet though, but you may have to. It doesn't matter though as it is hidden by the center consol.
Good luck with it all. At least it's not a dash change
