Old 30-10-2010, 08:41 PM   #1
robbyj
Rob
robbyj's Avatar
Default Diff gears to go with cam?
Just throwing this idea out there. If i can pick up this job im after ill be earning enough money to justify a cam + tune.
However i dont have much of an idea of what im up for.
So..
I don't care for top speed, would rather have torque. And that lumpy idle sound (if they go hand in hand..)
I was thinking of a Crow "Hi Torque" cam purely because of the name.
But im sure someone can mention a similar/better cam for torque
So questions.
Will a 'high torque producing cam have a lumpy sound?'
A different gear ratio will help with torque? is it worth it if i get a cam+tune
Will i need associated cam gear like valve springs etc? if so, what.
Will diff gears alone produce better torque as a worthy upgrade
Whats the best ratio for what i'm after
And what are the associated costs,
id expect around $1500 for cam+tune
(thats without taking into consideration associated cam gear)
Have no idea about costs of diff gears
Sorry about the questions but i want to gain enough knowledge if this goes ahead.
Thanks.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2010, 09:06 PM   #2
frd906
Read Montys build thread
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2010, 11:13 PM   #3
ebxr82nv
Look further afield than crow for a cam, I'll leave it at that.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2010, 05:25 PM   #4
SXR6
Still a Ford boy... Just.
SXR6's Avatar
+1
Originally Posted by Sprint
haha the boss reminds me of a amercan football player, big , muscular glory but a bit slow on the desicion making and up take...
Once they wake up its water boy time though.
SXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 12:54 PM   #5
Stattic
Stattic's Avatar
also +1
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 01:52 PM   #6
blueoval
Critical Thinker
blueoval's Avatar
What is said below is based on personal experience. This is by no means gospel and everyone will have their own opinion on the matter.
If you mean high torque as in producing torque 'down low' in the rev range, then NO would be the answer to this question. Generally lumpy cams have tighter lobe separation angles to produce the 'lumpiness' you often hear of in V8's. Generally speaking, and I mean generally, the lumpier the cam, the higher the rev range the engine will make power/torque. This in turn means you will either need a manual or high stall converter to make the car use the designed power the cam is intended for. Don't get me wrong, the car will still run, but it will be 'doughy' at low revs till the revs pick up and the cam is working in its designed rev range. Histalls and diff gears gets the engine to that desired rev range much sooner than stock.
Absolutely if you are looking for faster take offs from stand still. Also this will aid the engine to reach the cam rev range the cam is designed for, faster. Thus in turn, achieving the power quicker. In fact, I would not consider running a bigger cam without diff gears, OR if the cam upgrade is a mild upgrade, you may be able to run stock running gear ok.
This depends on if you are getting a reground cam, or new billet. As a rule of thumb, I recommend a new set of valve springs for a cam that is significantly designed for a lot more power. For a mild grind, you can get away with using stock valve springs if the manufacturer specifies it as ok. Consider asking the cam manufacturer for recommended valve springs at the time of ordering. Every brand is different so there is no real way of saying yes or no.
Cam regrind requires shims based on how much of the cam was ground in the first place. The supplier will recommend what size shims you need.
New cams do not need shims, but are more expensive
I wouldnt say diff gears 'produce' torque, but rather assist the existing torque of your engine to come on earlier in the rev range. If you care about getting to a given speed fast, diff gears will certainly give you this. Be aware there is a trade off. Your engine will rev a bit higher at cruising speed, fuel consumption will be affected.
I was told that for a street setup with auto trans go with 3.7 ratio. For a street setup with manual gearbox - 3:45 ratio will suit very well. Of course this will be argued due to everyone having different setups to suit different applications. But as a guide, the above ratios will suit a good street style setup.
With this, it can vary. Depending on if you went reground cam or new billet. Plus who does the fitting and tuning and what other items you need to get the most out of your cam. Don't just think throwing in a cam and a tune is all you need. You need to work out what you want your car to achieve. Is it for towing, street driving, circuit racing, drag racing, general daily driving....what? This will be the first thing the cam suppliers will be asking. Then they will need to know what stall speed you intend on running, diff gears, max rpm speed, wheel diameter size, tire size, the list goes on. Don't be one of the knobs and stick a massively lumpy cam in for 'fully sick' reasons. It will drive like a complete dog and your fuel consumption will suck at best, with no power when you most need it. Be smart about what cam you choose, and be honest about the application you intend you car to be used for.
Diff gears can vary. Speak to those who have already done it. Steer away from 2nd hand diff gears as they are prone to whining when fitted to aother diff. If you want to go second hand, seek a complete diff with gears, axles the lot from an xr model (assuming 3:45s are what you are looking for). I did this and found a diff for $500 with low km with 3.45 ratio. Fitted new diff oil to it and its fine apart from LSD needing to be repacked.
Hope this has helped.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 02:04 PM   #7
The Monty
Just slidin'
The Monty's Avatar
Id factor in 2k plus for the cam and tune.
Billet Cam (not regrind) - $600
Vernier gear - $220
If you want a big cam you will need:
Valve springs - $220 plus install - $300
Valve sring retainers
Xcal 3, chiptorque chip etc - $8-900
Custom tune - $600-1000
3.9 Diff gears, a LOKKA and install would be around the $1200 mark.
Ive done both, and can fully say with no hesitation that the diff gears are a 98683 times better mod.
Fastest AU other than Stiddy ran a 14.2 with standard cam, but theres barely a car under the 15 second mark without diff gears.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 10-11-2010, 02:08 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by The Monty
.....the diff gears are a 98683 times better mod.
Agree with this. Gearing is just as important as the cam itself when it comes to the 'holeshot' advantage. They work hand in hand.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 10-11-2010, 02:18 PM   #9
SXR6
SXR6's Avatar
Very well said blueoval.
The Monty is on the case aswell. Its about the cheapest and all you can do in that list before you start looking into things like head porting, engine rebuilds and all that kinda fun stuff.
I love these motors, more so than the twin cam barra motors. These engines have so much potential if done right.
Old 11-11-2010, 03:52 AM   #10
The Monty
Just slidin'
The Monty's Avatar
If you want to save money you can have my cam and Vernier gear, its a surecam cam, .535 lift, 218@.050 duration and 114 l.s. Comes on hard around 3500rpm, makes 410nm of torque, and will happily rev to 6400rpm. Vernier gear is a Crow Cams vernier gear. I also have a head here with the valve springs and retainers in it, but I would want that taken off by the person buying it. Whole lot for $750.
Old 11-11-2010, 12:06 PM   #11
blueoval
Critical Thinker
blueoval's Avatar
Is that the same cam you showed me in your youtube clip recently?
Dammit, why couldn't you be in SA.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 11-11-2010, 01:53 PM   #12
The Monty
Just slidin'
The Monty's Avatar
Same Cam, yes. Ill send the cam and vernier gear.
Old 12-11-2010, 04:05 PM   #13
robbyj
Rob
robbyj's Avatar
Sorry guys i have been away for a week.
Shav, love reading your replies as always. Thanks for answering everything. As you say not to chuck a cam in and be done with it. Yet to try find a job over the holidays, as i was actually on holidays, so just trying to research it a bit.
Thanks monty, just read your parting out the blue car thread and your cam came to mind instantly.
Ill keep researching and keep looking for a decent paying job before i make a decision. But ill keep you in mind.
It seems id be better off doing LSD and diff gears first however???
Old 12-11-2010, 06:36 PM   #14
The Monty
Just slidin'
The Monty's Avatar
Id do the diff gears first. If your thinking about racing it, Id steer clear of an LSD though, head for a LOKKA. If its for streetduties only, just get an LSD.
Old 12-11-2010, 06:41 PM   #15
blueoval
Critical Thinker
blueoval's Avatar
No worries mate. Hope I helped a bit. I would definitely consider how you drive your car and what your intention for it is. This will help determine the best way to go.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-11-2010, 08:01 PM   #16
FS5
if you want more torque and excellaration go the diff gears like mont said .for an au there the best bang for your buck. if you got an auto you'l need some sort of tune to get it to work.manual is easy get them fitted and just have fun.
if your after more torque from your motor ,try an xr6 cam ,get a vernier gear and advance it about 5* it will pull hard down low and still rev out ok.
i take it you'd have all the usual intake and exhaust mods done already?
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2010, 10:38 PM   #17
robbyj
Rob
robbyj's Avatar
Yea thanks mate, sort of in 2 minds at the moment, over the next few of years ill be looking for an AU XR8 as a weekend car.
Cant hurt to research it tho.
Yea extractors, CIA all that basic stuff. So looking into next step.
Would it really need a tune? that turns me off the idea now haha
Old 13-11-2010, 04:01 AM   #18
The Monty
Just slidin'
The Monty's Avatar
I think he means regarding shiftpoints and speedo recalibration. I didnt get a tune for a while after getting diff gears done. Youll just hit the rev limiter sometimes on WOT. I didnt have this problem as my lmiter was raised so when it was changing gears I was still doing the same speed as I normally would be, just at a higher RPM.
Old 13-11-2010, 08:36 AM   #19
robbyj
Rob
robbyj's Avatar
Ah k thanks
more to think about. Seems the next stage you have to start throwing some money at it.
Old 13-11-2010, 01:46 PM   #20
The Monty
Just slidin'
The Monty's Avatar
And none of it is worth it. I had fun doing it, but if there is a next time, I would deffinately go boosted.
Old 13-11-2010, 03:29 PM   #21
robbyj
Rob
robbyj's Avatar
Well thats what i always thought, strap a super charger on and be done with it.
Although of course there is still need for intercooling tune etc etc.
Old 13-11-2010, 06:25 PM   #22
The Monty
Just slidin'
The Monty's Avatar
If your after 200kwish there isnt a HUGE need for intercooling. Handy for sure, and deffinately worth it.
And you would need a tune.
For me, its like this:
Cam and associated bits and peices - $2400ish, if you want a ported head to match, $3500.
Supercharger and tune -From $5k.
Not much difference, and one ends up with 50kw more than the other.
dont get me wrong though, I have no regrets doing the NA way, heaps of fun, but money for the gain wasnt worth it imo.
Old 14-11-2010, 01:12 AM   #23
robbyj
Rob
robbyj's Avatar
Yea, it was interesting reading your builds, some great work. Also with N/A its like you didnt 'take the easy way out' by just bolting something on.
But if i was to do either id prefer the s/c
Old 14-11-2010, 01:37 PM   #24
MGM
MGM's Avatar
would 4.11's be ok for an auto xr8 ute towing a tool trailer everyday ??
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 02:25 PM   #25
blueoval
Critical Thinker
blueoval's Avatar
It would be more than ok. V8's have plenty of torque as it is to tow. Going with diff gears like that you will find the car is revving harder than it needs to. Fuel consumption will be compromised.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 14-11-2010, 04:32 PM   #26
MGM
MGM's Avatar
The car is on LPG to, so when towing it struggles to tow the 1300ish kg's plus the heavy car, I know it will rev at 2400rpm. It pulls the trailer fine but only getting up to speed is very slow
Old 15-11-2010, 11:18 AM   #27
blueoval
Critical Thinker
blueoval's Avatar
I would consider a capa flash tune for your LPG so you can customize power for towing over diff gears.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-11-2010, 11:44 AM   #28
MGM
MGM's Avatar
I was told for LPG tune that I have to get a custom tune on both fuels first so that would be around 1500, I've already got a capa box from my old car to
Old 15-11-2010, 11:48 AM   #29
blueoval
Critical Thinker
blueoval's Avatar
As long as it isnt an xcal 1 you will be fine. To some degree that person is correct. If you use LPG 90% of the time, you could effectively get away with running 1 custom tune up until you switch it from LPG to petrol. Then you would need to revert straight over to the petrol tune. A bit of rooting around. If you have to start the car on petrol, I would be inclined to pull over, reflash on petrol tune. That is the way I see it. Some one else here could possibly shed some light.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-11-2010, 10:18 PM   #30
MGM
MGM's Avatar
yeh i run lpg most of the time, petrol is only really for driving to the srevo when i have run out of gas, mabey 10km a week or so, il find out more about the tunes then, dont want to have to re-flash it everytime
