Old 09-11-2010, 11:59 PM   #1
boyracer
Default Au Wagon Starting problem
I have an auto AU falcon wagon that sometimes doesnt want to start. Usually when this happens i move the Tbar through all the gears, after doing that a couple of time its usually starts. Is there anything in particular i should replace?
boyracer is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 12:08 AM   #2
frd906
Neutural switch or the inhibitor switch on the side of the gear box seams to be causing the problem
On the passanger side of the gear box
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 12:15 AM   #3
boyracer
Thank you, will have a look in the morning.
