12-12-2010, 09:18 AM | #1 | ||
rexnet
im having problems with my ABS system. when i lightly break the warning light comes on. i've had he car diagnosed and code "C1155" for the L.H.F wheel sensor came up.
how can i find out what that code means and what would be the best thing to stop it. |
12-12-2010, 01:20 PM | #2 | ||
app diesel mechanic
ring ford.;)
daily driver: au series 1.5 forte sedan mods: clarion head unit, 15" alloys, ex police sump guard, futura grill,clear side flashers, AU s2 tailights,BA xr6 spoiler, kenwood 12" sub, kenwood 250W amp, kings sports lows, 2.5" lukey catback. mods to come: rims!! |
12-12-2010, 02:00 PM | #3 | |||
rexnet
12-12-2010, 03:34 PM | #4 | ||
You could have a number of things wrong with the sensor.
1) Sensor is dead 2) Sensor is filthy with metal filings over it (as it is magnetic) and needs a clean 3) broken loom to the sensor (has been known to happen). First thing I'd do is have a look under there ... if it is anything like the B-series ... they are held in with an 8mm bolt ... slide out and easy to clean (do them all if you can). If you cant see an issue with a broken loom ... and the light is still on after a clean ... try and get a 2nd hand sensor and replace it if you can yourself ... and see if that sorts it out. For starters.
12-12-2010, 05:21 PM | #5 | ||
Regulator
Don't forget to reset your ECU after taking the very good advice from above.
It's probably just a dud sensor.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
12-12-2010, 06:10 PM | #6 | ||
rexnet
To reset ecu do I return it to stock and leave battery unplugged for a few hours?
12-12-2010, 10:02 PM | #7 | ||
I can't believe that...
"i've had he car diagnosed and code "C1155" for the L.H.F wheel sensor came up." ...why didn't the diagnostic centre/guys give you the goss on the decode, as well as the probable cause? Cheers 4ford |
12-12-2010, 10:45 PM | #8 | ||
Prob dud sensor as previously mentioned. Is easy to test, just disconnect both front sensors and measure resistance between the connector terminals of both sensors with a multimeter. If the reading for the LHS sensor is alot different to the RHS sensor you know it's a dud. According to the WSM they should read 1.45k - 1.85k ohm for a good sensor.
Hope this helps wes
White MY04 Subaru Impreza WRX Hatch - Stock, airbox resonator mod, lowered on king springs Marine Blue EBII XR8 - GT40p's, Paceys, 3in mandrel bent exhaust, Explorer Manifold, YT 1.72 RR's, 65mm TB, 75mm MAF, Thermo's...now manual 1967 Ford Futura coupe 289 C4 stock cruiser
13-12-2010, 08:22 AM | #9 | ||
The Monty
4ford has a point whast the use in a autoelec/mechenic to do a diagnostic on a car and then make u find out what it means? they should have a book about 700 pages long with all code numbers from all makes and models as well as what the code means, hence its thre job to diagnose and find and fix
24-12-2010, 05:46 PM | #10 | ||
rexnet
i took the sensor in question out and gave it a clean. had a fair bit of metal shavings on it. i assume these assist to the ABS light coming on. hoping this stops it.
03-11-2011, 10:34 PM | #11 | ||
Did a search and came across this thread. Similar problem, abs light comes on.
Silly question, where is the ABS sensor that needs cleaning located and what does it look like? thanks.
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
04-11-2011, 07:48 AM | #12 | ||
Chairman & Administrator
I don't know why no one uses the DTC database we have:
DTC # C1155 Description: Left Front Wheel Speed Sensor Continuity Fault Mechanical: Sensor: Sensor fault Electrical: The sensor circuit may be open circuit. Wiring fault. Other: ECU Faulty Cheers Russ
Observatio Facta Rotae
04-11-2011, 08:41 AM | #13 | ||
rexnet
Russ you are a champion!!!! i now dont need to pay someone to tell me this!!!
XR8_007 its in behind the brake disc. you will see some 2 wires going to it.i think it comes out with an 8/10mmbolt |
04-11-2011, 06:55 PM | #14 | ||
Each wheel has a sensor.
AU XLS. |
05-11-2011, 06:44 PM | #15 | |||
06-11-2011, 11:28 AM | #16 | ||
rexnet
Fronts do have a sensor as well. I just swapped mine over and Ive had no issues touch wood.
$35 from a wrecker. |
