Old 01-01-2011, 01:37 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default how to Data Log with an X3
does anyone know how to data log with a SCT X3 tuner?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 01-01-2011, 01:43 PM   #2
JC807
sucksqueezebangblow
JC807's Avatar
you need to get a copy of Live Link - the sct software. plug in your x3 to both the obd2 port of the car and the usb of the laptop.
previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUX, 06 BF XR6T, 08 V50 T5 AWD , MY13 ISUZU D-MAX 4X4
current:-> 16 SS Sportwagon, 19 Everest BiTurbo 4WD
JC807 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 01:49 PM   #3
Day-mow
rexnet
Day-mow's Avatar
i can get live link from SCT website?
Old 01-01-2011, 01:51 PM   #4
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
Go to our Webb site and download the latest version of live link www.sctflashtuning.com
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 01:52 PM   #5
ratter
ratter's Avatar
http://www.herrodmotorsport.com.au/S...1/Default.aspx
You can download it from the link above which is herrods site
Pit Lane Performance
Old 01-01-2011, 01:54 PM   #6
Day-mow
rexnet
Day-mow's Avatar
thank you
Old 01-01-2011, 02:37 PM   #7
Day-mow
rexnet
Day-mow's Avatar
right its data logging on the unit. how do i get that into livelink?
Old 01-01-2011, 02:43 PM   #8
ratter
ratter's Avatar
you use the X3 as a pass through device and record the info to your lap top using the live link software
Old 01-01-2011, 02:46 PM   #9
Day-mow
rexnet
Day-mow's Avatar
worked that out now i just need to know what i should be watching
Old 01-01-2011, 02:47 PM   #10
ratter
ratter's Avatar
that's entirely up to you depending on what you want to know.
Old 01-01-2011, 02:49 PM   #11
Day-mow
rexnet
Day-mow's Avatar
well. im not really sure. hahahahaha
atm im data logging all fuel and spark stuff. just at idle in my car port. guess i really need to go for a drive. donno how long my lappy battery will last tho.
Old 01-01-2011, 02:51 PM   #12
Sprint347
Tickford
Sprint347's Avatar
ratter does the Xcal3 need to be 'paired' with a car to datalog?
Say my Xcal3 is to be used on on my T3, and I just wanted to 'datalog' a BF super pursuit.
Do I have to 'pair' the xcal3 and the pursuit, or can I just plug in the xcal into car/laptop and run up the software 'passively'?
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 02:53 PM   #13
ratter
ratter's Avatar
no the X3 does not need to be married to the car it is data logging
Old 01-01-2011, 02:55 PM   #14
Sprint347
Tickford
Sprint347's Avatar
Oh awesome, thanks!
BA XT
Old 01-01-2011, 03:04 PM   #15
Day-mow
rexnet
Day-mow's Avatar
i just went for a drive and as soon as i got out of my wireless network range it died. does data logging require internet?
Old 01-01-2011, 03:21 PM   #16
Sprint347
Tickford
Sprint347's Avatar
I can read the car's strategy (HAANG), and the X3 speaks to the software and car fine... but I don't get any data?
BA XT
Old 01-01-2011, 03:23 PM   #17
ratter
ratter's Avatar
No, you should have the X3 plug into the car and the other end into a USB port
Old 01-01-2011, 03:24 PM   #18
ratter
ratter's Avatar
you have to select the info you want to log
Old 01-01-2011, 03:27 PM   #19
Sprint347
Tickford
Sprint347's Avatar
I selected 24 inputs (eg. tps/maf volts/rpm) but everything reads as 0
BA XT
Old 01-01-2011, 03:31 PM   #20
ratter
ratter's Avatar
try a couple at the start, not all of them will read,
pick some that work, save them and add more as required
Old 01-01-2011, 03:33 PM   #21
Day-mow
rexnet
Day-mow's Avatar
i found you need to click on the graph icon in the live link and it'll select some stuff and graph it.
also may need to do a software update and let the Flash unit install on the pc
Old 01-01-2011, 03:42 PM   #22
Sprint347
Tickford
Sprint347's Avatar
The X3 is connected to the car, no worries there.
X3 reads 'LiveLink Activated CAN Detected'
I've clicked the graph button and added a heap of inputs but everything reads '0'.
'Module' set to 'ECM #1', Rapid Packet enabled and set to 'Ford'.
If I 'Detect Processor ID' it comes back with 'HAANG' so I know the X3 and laptop are talking.
X3 is not 'paired' with the vehicle.
BA XT
Old 01-01-2011, 03:45 PM   #23
ratter
ratter's Avatar
Stupid question, but have you pressed the green button to start logging after starting the car
Old 01-01-2011, 03:47 PM   #24
ratter
ratter's Avatar
do not do a software update on the X3. Not sure but it may change the aussie settings and stop it tuning abilities.
Old 01-01-2011, 04:05 PM   #25
Day-mow
rexnet
Day-mow's Avatar
it wanted to do a software update on the livelink?
i hope i've not stuffed mine.
Old 01-01-2011, 04:11 PM   #26
ratter
ratter's Avatar
update on the X3 or the livelink software?
software should not be an issue for livelink, but ot sure about the X3 if you updated that, may pay to talk to Herrods if you have updated the X3
Old 01-01-2011, 04:17 PM   #27
Day-mow
rexnet
Day-mow's Avatar
live link
Old 01-01-2011, 04:23 PM   #28
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Ive been stuffing around with mine countless times, logging with hand held only or plugged into laptop it works ok, but unfortunately once im on the move it either freezes or says "lost communication"........Makes me want to put it on the road and line it up.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 05:02 PM   #29
Day-mow
rexnet
Day-mow's Avatar
thats what mine does
Old 02-01-2011, 11:08 AM   #30
Day-mow
rexnet
Day-mow's Avatar
So watching fuel and knock and then trim up fuel where it's running rich would work?
