Critical Thinker
Hey guys, I know this question doesn't belong in this category but I want to fit my stall converter in my car, and I was wondering if I needed to re-tune my car for it with the flash tuner?
Sounds like a dumb question to ask but I better ask you guys before I go ahead with it.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
Yeah you will, shouldn't cost bugger all, but will need to make a change so it doesn't go into limp home mode when stalled up.
Critical Thinker
Thanks Brendan. Appreciate that feedback.
Smile
You need to retune the car. The reason being that the higher stall will have the load changed on your engine and it will have different ignition timing and fuel ratio adjustments to take advantage
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Critical Thinker
Thanks stav that makes sense. Tell me, do u notice a big difference in take off woth a stall?
Lost Boost Gained Class
Stalls are fun Iv got a 3000 in mine it gets annoying sometime as the car almost revs to 3000 before it take off like a rocket if u stall the car right u will launch it off the line well I normally take off at 2200
2006 BF Fairmont Ghia
2001 AU Falcon |
Critical Thinker
Cheers for that feedback mate. Thats great to hear. I only have a 2400 stall, but am hoping it will be big enough to make a difference off the lights till boost really hits. My car makes good power from about 2300rpm on so I wanna make sure I remove any possibility of lag up to that point. Would be nice to be able to break traction from stand still too.
Ahahah power skids
2001 AU Falcon |
Blueovel.... You should bring your car to melb and race it at heathcorte park at the nats
2001 AU Falcon |
Let me know how you go Blueoval.
I have been umming and arring about a stall for a long time!
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
#11 | |||
Critical Thinker
As for drags at Heathcote, I would love to but with work commitments its difficult to consider.
#12 | |||
Critical Thinker
I will provide a full run down on what everything is like when its all fitted, including cam, xcal3, stall, etc. I have an app on my phone that I can use to give a rough estimate of 0-100 times too so I will use that before and after to give a rough indication of the improvement.
#13 | |||
Smile
So you need a good stall first and then a tune to make the car work with the stall to optimise acceleration.
#14 | ||
i should put a 0 - 100 vid up so blueovel can have a idea on what its like if he likes
2001 AU Falcon |
#15 | ||
Critical Thinker
cheers fellas, the stall I have is a modified stock stall. Nothing special, but hopefully gives me better take off than stock.
#16 | ||
Critical Thinker
Just reviving an old thread.
I went and saw my tuner yesterday to get his opinion on what it would take to get my stall converter fitted and if I needed another tune. He reckons I shouldn't need to and it can be done based on my current tune ok. So with that in mind, Im going to book it in and see how I go with it. Will report back and let you know what the outcome is when its done. ![]()
#17 | ||
it`s sounds like good thing to overcome that tall 1st gear in these things, , a couple of years ago i talked with a torque converter builder and his recommendation for a nice compromise was a 2500rpm, obviously some guys want it a bit wilder, i will be interested to hear how it goes Shav.
#18 | ||
Critical Thinker
will let you know mik. I'm booking it in for 2 weeks time so Im hoping the 0-100 times will drop at the minimum. But ultimately the engine will be on boost a lot sooner. This could be the best mod I do to the car, if what Im hearing is right.
#19 | |||
I have never put it into limp mode accidently ... only on purpose while experimenting... |
#20 | ||||
rexnet
#21 | |||
Critical Thinker
![]() Im not sure what they call it on the iphone but on Android phones its called speed view and its free.
#22 | ||
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Shav, for what it is worth, I installed a 2600 hi stall in mine - no tune required. Runs like a dream and gets of the line a heap better too!
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
#23 | |||
All Ford Club Life Member
![]() ![]() Join Date: Aug 2005
Mine too.. I've got a custom tune live tune done few ago from chiptorque. about 6 ago I got a 2600 stallie fitted, no retune need, never even thought about Limp home mode, never had a problem and yes it halls of the line like a freight train now ![]() and I'm getting much better fuel economy too, the engine is no longer under as much load when cruising on the Hwy at 2000 rpm and 100km/h I spent the extra and got a 9" light weight racey version, couldn't be happier...... well with a supercharger maybe ![]()
Worked AU XR8 Ute - Toy Std FG XR6T Ute - Daily Supercharged BA 6 Ute - Wife's daily 351W F150 93 XLT 4x4 Supercab |
#24 | ||
Smile
It will go better but go much better if its tuned to accomdate the higher stall.
#25 | ||
Critical Thinker
Thanks guys. That's what I was thinking too. Sounds like something that should have been done a long time ago. So I will get on it.
Stav - totally understand what your saying mate. I think a tune will get a tad more benefit, but with the current tuning situation of mine being a cost vs benefit (i.e. xcal1 ---> xcal 3 upgrade) I think I will see how the car goes with the stall as is.
#26 | |||
5.6L x 2 pilot
Good luck & Cheers Stu
#27 | ||
Critical Thinker
Thanks Stu. For some reason I have a feeling this will nearly give me as much thrill as when I fit the s/c on originally. I not counting my chickens yet, but I am looking forward to some good acceleration from the lights, which is what I have been missing since the s/c was fitted.
#28 | |||
5.6L x 2 pilot
Enjoy Stu
#29 | ||
Critical Thinker
haha, yeah a bit of an over exaggeration I know, but we'll soon see the changes. Will report back when it gets done.
#30 | ||
Critical Thinker
Anybody know what it costs to fit a stall in an au?
