17-05-2011, 10:04 PM | #1 | ||
Just another mock-up..
Ok..
Seems I may have hit a snag.. not a big snag, but a snag none the less.. The TS50 that I am getting the gearbox and ecu out of for the ESS conversion is a 12/99 build.. My car is 4/99 build.. Now, from what I can see and remember, it seems the TS50 is a series 1.5 and has smartshield.. Mine is a series 1 and has smartlock.. What I want to know is.. If I put the TS50 (series 1.5) ECU into mine when I put the gearbox in, will the car start..? Is smartshield run by the ECU or the BEM or is it a combined thing..? Will I need to convert my car to smartshield to run the TS50 ECU...? Will I need the BEM and key from the TS50..? Will any wiring need to be changed..? Should I just grab the whole lot and change the ECU, BEM, Key and barrel..? Is there anything I have missed..?? Cheers Guys..!!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
17-05-2011, 10:20 PM | #2 | ||
if you can it'd probably be easier to grab the whole lot. i'm sure someone else will know for sure if you can get your original bem paired to the new ecu.
17-05-2011, 10:24 PM | #3 | ||
Lacking Imagination
just put the t series BEM in the car.. makes it more a T-Series ;)
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
17-05-2011, 10:36 PM | #4 | |||
You can't stop the signal
You have a small memory don't you kris.
It won't work. Series 1 to 1.5 on my dash didn't work (ute's are 1.5, dash I got was a 1) . The smartshield light would flash ( I think, not sure actually) and the car wouldn't crank over at all. That was on both series 1 and 1.5 bem's. I sent it to ford like this to get matched and they couldn't do it. Their words were "component miss match" What I traced it down to was the bem and their is a comm's (serial data) channel that in series 1 goes from the ecu to the cluster. In series 1.5 it runs to the bem as well. I belive that was the only difference i could find. I will check my notes in the next few days (about an 1" high worth of papers) I can tell you it wasn't easy to find. I had both dash looms out and accessible, and went though pin by pin tracing where each wire went. I'm pretty sure I noted down all of the differences. The good news is that it is only about 1 foot of wire. Bad news is the dash has to come out and apart to access it. If you want I can try the series 1 fairmont bem in the ute on the weekend and see what it does. Any other question, just ask. Happy to help out. Cheers [EDIT]Check the BEM colours. Your's should be olive and the TS a yellow.
17-05-2011, 10:40 PM | #5 | ||
Just the man I was hoping to hear from...!
Taking the whole dash out will be done as I need to do the blend door anyway... So If I change the Fairlane loom to the TS50 dash loom and plug the TS50 ECU and BEM and change the key and barrel, It should start yeah...? Thanks man..
17-05-2011, 10:41 PM | #6 | ||
Lacking Imagination
if you can get it, do it
then send me the loom so i can convert mine to a V8 one day
17-05-2011, 10:48 PM | #7 | |||
Just to make you look forward to it, just a photo I found of testing to find out what wrong.
17-05-2011, 10:49 PM | #8 | ||
motherfaaaaaaaaaaaaaa
17-05-2011, 10:52 PM | #9 | |||
I don't see why it wouldn't mate. If your going to the effort to swap looms, why don't you just put the TS dash in there?
But it can be done. That was my motto in the end. "I've spent enough time on this, IT'S GOING TO WORK" I didn't come across any problems in the engine bay side of it. At least not series related. Just XL spec not getting certain wiring.
17-05-2011, 10:57 PM | #10 | |||
At least you didn't have to do a cross car loom as well
17-05-2011, 11:02 PM | #11 | |||
I'll change the loom, ecu, bem and key/barrel and go from there.. There can't be any component mis match if its all from the same car.. Also both mine and donor car are high series so I cant see much of a difference there.. Thanks again man..!
17-05-2011, 11:03 PM | #12 | ||
Lacking Imagination
get me a grill :P
17-05-2011, 11:07 PM | #13 | |||
What I am saying, is to change the dash loom the dash has to come apart. Vinyl top separated form the plastic bottom. ala what the pic 2 above is. Plastic bottom is in the car
A lot easier to just put the TS dash in, if it's up to your standards. Cheers
18-05-2011, 08:20 AM | #14 | ||
must say you guys have a lot of patience. I would have been in a white jacket and gettin thrown into an ambulance after an hour or on the floor with a empty bottle of scotch. GOOD LUCK hope it works out.
18-05-2011, 08:38 AM | #15 | |||
Ahhh.. I get you know.. I'll do that man.. Thanks for the heads up.. Much appreciated..!! If i get stuck you'll be coming over for a beer.....hahaha Cheers
18-05-2011, 11:01 AM | #16 | ||
All sorted..
I've spoken to the guy I get my parts off and spoke to a head mechanic at Ford.. What I will be doing is swapping ALL the TS50 stuff (dash, loom, ecu, bem, key and barrel) into the fairlane.. By doing this it will all plug in and work perfectly..! Will be changing the key lock on the drivers door handle and central locking fob so i wont have to have 2 keys for the lane.. IT WILL WORK!!! haha Thanks for all the help guys.. Glad I sorted this out before getting too far into it.. Much Appreciated..!
23-05-2011, 10:22 PM | #17 | ||
Ok.. going to tackle this on the weekend...
Does anybody have step-by-step instructions on the easiest way to remove the complete dashboard..? Cheers Kris
23-05-2011, 10:24 PM | #18 | ||
meh.
In the AU Wagon's old thread on the first page I included an entire guide with pics to remove the dash.. I doubt anyone has realised that though..
23-05-2011, 10:25 PM | #19 | ||
hahaha... cheers mate..
I'll take a look..!
23-05-2011, 10:31 PM | #20 | ||
Lacking Imagination
Hammer & Chisel
23-05-2011, 10:59 PM | #21 | |||
My advice is to remove your seats so that they aren't damaged as the dash is more large and awkward than heavy. Door trims too.
Same goes for ECU (you've got to change it anyway) Column doesn't have to come out, but it does need to be dropped. That's about all of the special points I can think of. Cheers
24-05-2011, 08:39 AM | #22 | ||
Cheers mate...
I will be changing the coloumn too as it's easier than changing the barrel and key and clock spring seperately.. You know, just all in in one hit..!! Thanks for the advice again mate..!
24-05-2011, 09:27 AM | #23 | ||
Well having done a dash only a week ago I can say pulling the front seats, door trims and center console will make the lifting it out a lot easier. I would also detach the column near the firewall (1 x 10mm bolt and spring clip. this way the entire column will come out with the dash). Be carefull the plstic of the dash in the middle under the windscreen doesn't snap off. I would make sure it has released from the insulation on the firewall. I didn't do fhat and broke a little bit off. If you like I will get some photos tonight as the dash is sitting in the shed.
Rhys
Toy Car Build |
24-05-2011, 09:31 AM | #24 | ||
Thanks for the info Rhys..!
Much appreciated...! Will keep everyone informed of how I go..!!
24-05-2011, 04:28 PM | #25 | ||
Lost Boost Gained Class
my Bem is yellow (1.5 ftw)
2006 BF Fairmont Ghia
2001 AU Falcon |
25-05-2011, 06:57 PM | #26 | ||
Ok, Lucky last questions..
Is there any difference in the Series 1 loom and series 1.5 loom..? I mean, will I be able to plug the ECU, BEM and dash with Dash loom and there won't be any different plugs, or leftover plugs for that matter...? This is where I'm at atm...
25-05-2011, 07:16 PM | #27 | ||
Just thinking about the plugs I think they will all be the same except for one. I could easily be wrong but the plug which goes on the crash module for the later wiring loom I think will be a square plug and the earlier ones are a rectangle plug. Looking at that last pic the crash module is an earlier one with the rectangle plug.
As I said I could be wrong but I changed the loom on 2 dashes the other week. The series 2 loom had the square plug and the series 1/1.5 (yellow bem) had the rectangle plug. Hope that all makes sense.
Toy Car Build |
25-05-2011, 07:18 PM | #28 | ||
Thanks mate... So in saying that..
The S1/1.5 have the same rectangle plug then...? Cheers
25-05-2011, 07:50 PM | #29 | ||
Yeah that is right Kristo. Sorry must have had some brain fade for I thought you were putting in a series 2 dash!! Lol.
Keep up the good work. Rhys
Toy Car Build |
25-05-2011, 07:51 PM | #30 | ||
hahahaha..
No probs man... I appreciate the info...!
