Old 16-07-2011, 05:08 PM   #1
J_Putz
J_Putz's Avatar
Default start ya bastard
Am I supposed to remove the air filter before using this stuff?
I ask because my air filter is brand new and I'd rather be safe than sorry.
J_Putz is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 05:20 PM   #2
DJR-351
I am Groot
DJR-351's Avatar
Default Re: start ya bastard
What no instructions on the can....???
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 05:24 PM   #3
J_Putz
J_Putz's Avatar
yeah I've read it allready. Doesn't specify whether to spray the actual filter or remove it.
Old 16-07-2011, 05:26 PM   #4
sgt_doofey
sgt_doofey's Avatar
Is it a carby engine?
I would personally remove the air filter if I was to do that.
Cheers,
Sam.
Old 16-07-2011, 05:28 PM   #5
Veefore
Don't bother removing the filter unless you can't get the spray into the engine.
I used some of this stuff this morning to start a difficult motorcycle and just squirted it into the opening in the airbox.
Veefore is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 05:50 PM   #6
DJR-351
I am Groot
DJR-351's Avatar
It doesn't specify it cause you don't have to......remove it that is....
I am assuming this is a carby fitted engine....?
McLaren F1
Dick Johnson Racing
Old 16-07-2011, 07:36 PM   #7
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
If it's a carbed engine, remove the filter and squirt it down the throat to get it going. It's an EFI engine, squirt it down the piping that runs between the filter housing and the throttle body.
This way, it's getting the "full" dosage, rather than some of the stuff getting "trapped" in the air filter.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 16-07-2011, 09:37 PM   #8
IronFalcon
I've always just sprayed it on the filter... liberally.
IronFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 09:45 PM   #9
graham7773
I'm with him^ ^It will not hurt your filter as it becomes a gas/vapour almost as soon as it leaves the spray can. Don't be smoking when you spray it. It will also knock you out if you get a lungfull, it's main ingredient is "ether" once used to do surgical operations
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 10:16 PM   #10
GasoLane
Former BTIKD
GasoLane's Avatar
'Air Cleaner' is another way of saying Air Filter. And in DJR's post it makes it quite clear how to use it.
Old 17-07-2011, 12:07 AM   #11
2011G6E
2011G6E's Avatar
Magic stuff...used to use it a lot to start an old 1938 DeSoto I had in the back yard. Lift the air cleaner, spray down the carby, turn the key and whomp...starts like a new one!
Either that or backfires a two foot flame out the carby...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 01:36 AM   #12
smally289
growing up is optional
smally289's Avatar
Works a treat on eyebrows too
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 07:21 AM   #13
John G
John G's Avatar
I give the missus a short burst of it to try and get her out of bed and up to do some very rare house work, but it did no good. Worked wonderfully on a XB Ford the day before.
John G is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 07:38 AM   #14
RAREV8
Previously ScottishXC
RAREV8's Avatar
I hadn't started the coupe for about a month and a half- after no success one blast down the carby throat had it started and idling perfectly......it sure cleans out the crap effectively and gets things firing!
Personally, I don't remove the filter, just the cover and spray directly into the carb....I use a 14" filter so it's easier.
If you have a small filter or more modern type, just spray directly into it.
Great transactions with the following members:
BJ
Gilesie
XAGTCoupe
Pilch
Aussie_afroman
Donut King
Bad Boy Benny
BAWITHLOT
Greenmachine
Pinkbits
CUZ351
OhioXB
Falconunbelievable
4VXC
Uncleraggy
FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project
Originally Posted by 4Vman
Im just bored of the single/narrow minded...
RAREV8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 05:13 PM   #15
Spanrz
Hmmmmmmm!!
As far as I am concerned, it's a fantastic product..........except..........That it's a drug to the engine.
Yes, to removing the filter.
It's like cocaine to a drug addict. It wants more and more. It "does" stuff the engine over a long period of time.
The reason I know, is that I have seen large Earthmoving machines that need this stuff to start, that is, that will not even run without it.
I've used 2 cans once trying to start a Scraper.
Older diesels needed it, due to inoperative heating systems or poor combustion.
Becareful what you use it on.
Spanrz is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 07:13 PM   #16
big_landau
yeah they do get addicted to it.using it from time to time has no real affect on a motor and i have found the best way on a carby engine is to open it up and spray it straight into the motor.
big_landau is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 07:50 PM   #17
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
I use this and aerostart to set things on fire which I dont want on fire.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2011, 09:03 AM   #18
vibe_xr6
vibe_xr6's Avatar
We had an old UD water truck that used to live on it when winter came around ( glow plugs were working as well ) It wouldnt start without it but once summer came around she wouldnt need it, i have never ever had to pick up a can for my scraper or any other machines
Completely Stock
vibe_xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 07:33 PM   #19
Pedro
Pedro's Avatar
This product and Aerostart of which it is a copy are the best products bar none to kill ticks. As soon as you detect a tick on your body, spray it with Aerostart and it dies instantly, thereby stopping it from injecting it's toxic saliva into you. After spraying, don't try to pull it out. Just leave it and it will drop out after a while. If you don't believe me try Googling it.
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 07:38 PM   #20
NudgE^SIKBRO
Never late with a V8
NudgE^SIKBRO's Avatar
Ive always pulled the filter off and sprayed directly into either throttlebody or carby... I used to use it to start the Austin because it sits around for months on end, these day, a smige of 2 stroke because I always have some handy for the mower etc...
My Rides
(Daily)2004 Explorer V8 Limited
(Work) 2014 Kenworth K200 Aerodyne
(Classic) 1969 Mini K, 1340, twin SU's
The beginning is near!!!
Body by Ford. Soul by NudgE
NudgE^SIKBRO is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 07:39 PM   #21
GasoLane
Former BTIKD
GasoLane's Avatar
And if that doesn't work hold a lit match in the spray and then watch the little buggers run
Old 19-07-2011, 08:22 PM   #22
ebxr8240
Performance moderator
ebxr8240's Avatar
In cold mornings..
We used to pour metho down an old Fordson Dexta [3 cyl Perkins] inlet and set it on fire with inlet
manifold heater..
When it was nearly out..
We would start it...
Daily driver GTE FG..
