Old 18-07-2011, 06:24 PM   #1
AGE1%
Default Au2 2003 tickford xr8 200kw
I just bought new topgun standard leads and platnium sparkies(plugs) from autobarn, and installed and they seem ok. Before that on the same day i went to a recommended shop and asked for good oil and filter. The guy gave me 20/60 oil and a cheap z9 filter (as i found out after i fckd er a bit! coopers make good filters aye !). The recommended shop didn't have the leads and plugs thank god. Anyway the car seems pretty good except it seems to labour and flatten out in certain rev ranges. I have used the wrong oil have't i? it seems too thick? I am humbley asking what is the best oil to use in my pride and joy? I gave her 5.5 ltrs as the manual said but it seems too much on the dipstick. Any feedback would be muchly appreciated... cheers... Age...
AGE1% is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 04:03 PM   #2
Sep 97 EL XR8
Miami power
Default Re: Au2 2003 tickford xr8 200kw
i use 10w/40 in my EL xr8, i think i put about 5 litres in.
Sep 97 EL XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 04:13 PM   #3
RAPID_BA
Sounds a bit off oil shouldn't make it behave strangely in certain parts of rev range?
Something else I reckon
RAPID_BA is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 05:04 PM   #4
Cúl-Báire
Coils, plugs or leads will be your problem IMO.
Cúl-Báire is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 05:16 PM   #5
FGII-XR6
FGII-XR6's Avatar
top gun leads are your problem had nothing but trouble with my last set went back to standard ford ones problem solved
[SIGPIC][/SIGPIC]
Rides:
Old 19-07-2011, 05:31 PM   #6
You Yangs
Dunnydore Destroyer
You Yangs's Avatar
I once used a 25W70 oil over a summer period a few years ago, fuel economy rose a little but she ran fine so I don't think the oil is your problem mate.
______________________________________
"SKIN ON SKIN, LET THE LOVE BEGIN"
You Yangs is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2011, 05:58 PM   #7
MattSAU2XR8
As regards leads:
- You can get genuine Ford ones with the nice heat shields etc. on ebay for about $180 delivered.
- Any chance you can test the resistance of your old ones with a multimeter to see if they are still OK? I know they MIGHT test OK and still not be perfect on the car, but a more likely scenario is that a dud lead will just test as not OK. Then you can just replace that one lead.
- For that matter you could also test the top gun leads for resistance and if one is a dud then just get that one replaced rather than getting a whole new box of potentially dodgy top gun leads :-)
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
