Old 27-10-2011, 07:30 PM   #1
muzz
Default AU Falcon muffler replacement
Hi,
our AU has a hole in the big muffler in the middle. I notice on ebay you can get the middle piece which is like two mufflers connected by a pipe, part no. M3869. It looks like a fairly simple bolt off bolt on job to me, has anyone experienced any hassles doing this?
Thanks.
muzz is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 07:42 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: AU Falcon muffler replacement
Nup.... Should only take 1 hour or so to get the old system off, and the new one on...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 08:22 PM   #3
muzz
Cool, thanks.
Old 27-10-2011, 08:35 PM   #4
falconhell74
falconhell74's Avatar
Are you only replacing the center muffler ? if so it's normally a pain in the butt to remove rear section without damaging it. you would be better off replacing from the cat back , & its also a perfect oppertunity to upgrade to a 2 1/2 " system - better note & better fuel economy , not much more $ either
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 09:36 PM   #5
Day-mow
rexnet
Day-mow's Avatar
It depends on how they join. Sometimes they are clamped and sometimes they are bolted together. Suggest just buy a cat back. If your car is just a sedan yo can get them for under $200. And it's easier and you'll get better fuel economy and power.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 02-11-2011, 08:56 PM   #6
muzz
Hi,
Bought the centre assembly from ebay which came quick. But perhaps should just have bought the cat back as suggested since I can't seem to separate the last section from the centre assembly. The section is joined with a pipe clamp (u-bolt clamp) which came off easily, as did the bolts on the flange at the front. It probably has glue or sealant holding it together. Also I don't have much room to move as I just had the car on jack stands, so I can't get any real leverage.
I haven't tried WD40 to see if that works.
I think my options are to take it to a mechanic, or try and angle grind the pipe and put on a new rear piece as well. Although I couldn't get the rear section off either because the rubber hangers are a pain, so that may not be an option.
Any suggestions for the silly situation I have got myself into would be appreciated.
Old 03-11-2011, 07:28 AM   #7
falconhell74
Yep told you its a pain , get a screwdriver between the 2 pipes & bash it in past were the u bolt went in a couple of places as it crushes the pipe a little bit denting them in & also gets corrosion between them, then get a block of wood & a big hammer & bash the hell out of it & wiggle it etc . For the rubber mounts get some silicone spray & liberaly spray around the pin holes this will help them slide off easier
Xc falcon
Previous fords-
Old 03-11-2011, 08:51 AM   #8
Day-mow
rexnet
Day-mow's Avatar
i think they heat them up to help join them. thus why suggested buy a whole new cat back. but such as life.
ive found a slim long flat head screw driver helps get the rubber hangers off as well.
Old 03-11-2011, 05:44 PM   #9
muzz
Thanks for the replies. Will probably get a new tailpipe section and cut off the old one. It's not that expensive anyway for a new section. I already have some silicone spray in the garage so that should help with the rubber pieces.
Old 08-02-2014, 04:37 PM   #10
Rfordsfun
Hi all opinions on replacing stock au2 fairmont exhaust, with hi flow cat 100/200, new ebay middle muffler, already new lukey rear muffler (carline) all 2.5 ? Current stock is rusted and holes lmao. Thanks
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2014, 09:40 PM   #11
falconhell74
If you are going the high flow cat then go the whole hog and get some extractors as well .
2 1/2 " is the best size to go on a stock rocket :-)
Xc falcon
Previous fords-
Old 13-02-2014, 06:48 AM   #12
UWANT1
I have noticed that pics of extractors that I have seen don't have the stock heat exhaust shields put back in place is it that there not required anymore or is it they don't fit there after the change out. And if the shields were there as stock and not there after the change out were the stock shields doing anything? or were they there to make the bay look a bit prettier. Just wondering.
Cheers Mark
UWANT1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2014, 04:25 PM   #13
david lee
Originally Posted by muzz View Post
Hi,
Thanks.
canterbury exhaust did mine front to back $190
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 10:42 AM   #14
fordfalconed
Talking Re: AU Falcon muffler replacement
Gidday David lee and other lads,
What exactly did you get from canterbury exhaust for the $190? 2.5" diameter stainless steel pipes or cheaper motoline brand pipes and mufflers? From the cat back? or included the cat?
My hole is in the top area large centre muffler which sadly is stock welded to the end pipe resonator and no U clamp. I have a Au3 sedan SR auto petrol any helpful suggestions welcomed.
ps I have plugged hole with permatex grey coloured exhaust paste for the time being.
fordfalconed is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2014, 09:00 AM   #15
naughtyfalcon
to get the rear tail pipe separated just get a screw driver and hammer it around the out let lifting it , spray some wd40 on it bash a bit more , it will come off , had to do this several times.
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2014, 07:28 PM   #16
SirHenry
Falcon Unbelievable!
If you are after a good value, long life, improved fuel economy and nice deep and distinctive note look at a 2.5" Mercury exhaust and hi flow cat.
Not sure where you get them in Sydney but here in Brisbane was at the local exhaust centre. Got 4 or 5 years out of it before I sold my AU and exhaust was still going strong.
Chris
SirHenry is offline   Reply With Quote Multi-Quote with this Post
